16c505
Results 1 to 4 of 4
Thread: 16c505
    Jun 2004
    Wink 16c505
    Can anyone tell me if the 16C505 is compatable with PBP?
    If so, can I use internal clock?
    Thanks again!
    Oct 2003
    holland
    If you use PBP version 2.45 then it is there.
    Also the internal clock can be used with this compiler.
    Jun 2004
    Thanks Mat
    "If so, can I use internal clock?"
    PBP doesn't care about your'e using internal 4MHZ or external 4MHZ crystal. It's only a configuration fuse that you set at programming time.
