Program too long?
Results 1 to 8 of 8
    Sep 2005
    Campbell, CA
    I believe the problem is that your program is creating too many temporary variables. The program isn't too long, but you will have to simplify some of your lines. Break up some of the longer statements into two or more smaller ones.
    Charles Linquist
    Perth, Australia
    Thanks Charles.
    It was this line causing the problem:
    IF (temp>=$32 AND temp<=$47) OR (temp>=$3A AND temp<=$40) OR (temp>=$5B AND temp<=$60) OR (temp>=$7B AND temp<=$7E) OR (t2b_word_length+index=t2b_focus_length) THEN
    I'll expand it out into a number of IF statements and that'll fix it.
    Cheers
    IF (temp>=$32 AND temp<=$47) OR (temp>=$5B AND temp<=$60) OR (temp>=$7B AND temp<=$7E) OR (t2b_word_length+index=t2b_focus_length) THEN[/QUOTE]
    You can get rid of one of the temp-AND cases in the >$32 and <$47...first couple of ANDs
    Might save just that one AND/OR temp variable right there...
    Perth, Australia
    thanks skimask, cos u actually pointed out a bug in my code there. the first set should have been $20 to $2F... i accidentally put the decimal numbers in instead of hex.
    thanks Kamikaze47, cos u actually pointed out a bug in my code there.
    Should have been ...
            ifdef T8
                ifndef NO_T7_WARNING
                    messg "Temp variables exceeding T7"
    Then it would display a relevant "Warning", instead of obscure errors.
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
