Program too long?
Results 1 to 8 of 8
    Perth, Australia
    Default Program too long?
    Im working on a fairly large program, and ive been working on a number of subroutines in separate files which are to be included in the main program.
    Each file will compile fine on its own, but when I include all of the subroutines or copy/paste them all into one .pbp file (about 2300 lines long), I get the following errors on compile:
    Warning[207] main.asm 1525 : Found label after column 1. (warning)
    Error[108] main.asm 1525 : Illegal character (")
    When I look at main.asm line 1525 i see this line:
            ifdef T8
                ifndef NO_T7_WARNING
    this line >>>   warning "Temp variables exceeding T7"
    It looks something to do with interrupt context saving? I'm using DT's instant interrupts.
    Could my program be too long somehow? I'm not running out of codespace on the PIC so i cant see why that would be the case.
    Can anyone help?
    *edit* If i remove the interrupts from my code it compiles fine, so its def something to do with interrupts.
    Perth, Australia
    Cant see the connection between that and the problem i'm having.
    Sep 2005
    Campbell, CA
    I believe the problem is that your program is creating too many temporary variables. The program isn't too long, but you will have to simplify some of your lines. Break up some of the longer statements into two or more smaller ones.
    Charles Linquist
    Perth, Australia
    Thanks Charles.
    It was this line causing the problem:
    IF (temp>=$32 AND temp<=$47) OR (temp>=$3A AND temp<=$40) OR (temp>=$5B AND temp<=$60) OR (temp>=$7B AND temp<=$7E) OR (t2b_word_length+index=t2b_focus_length) THEN
    I'll expand it out into a number of IF statements and that'll fix it.
    Cheers
    IF (temp>=$32 AND temp<=$47) OR (temp>=$5B AND temp<=$60) OR (temp>=$7B AND temp<=$7E) OR (t2b_word_length+index=t2b_focus_length) THEN[/QUOTE]
    You can get rid of one of the temp-AND cases in the >$32 and <$47...first couple of ANDs
    Might save just that one AND/OR temp variable right there...
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
