Maths - Summing small numbers with decimals
Results 1 to 11 of 11
    SWITZERLAND (french speaking)
    I'm in the office and can't test this right now so I ask further.
    Do you know if I can store WORD sized numbers the same way you show me?
    The DATA command allows to do this, but WRITE?
    >>> just found the answer: Yes, it is possible. I'll have to try this when I get back home...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2421&stc=1&d=120590965 5">
    Roger
    Yep. DATA is at program time, WRITE is for run time.
    Default Help!!!
    Since I'm using interrupts, storing data with WRITE might sometimes be too long in conjunction some ADC processes.
    How do I store numbers greater than 65535 in variables and reuse them?
    I'm lost.
    Roger
    Since I'm using interrupts, storing data with WRITE might sometimes be too long in conjunction some ADC processes. How do I store numbers greater than 65535 in variables and reuse them? I'm lost.
    PBP 2.50a handles LONG variables, 32 bits, numbers.
    Default ...
    Y a plus qu'a cracher au bénitier!!!
    Roger
    Again, typical small U.S. school's got me here...I don't get it
    Me = uni-lingual ... there's a better word for that, but I don't know what it is off hand...
    My point is that PBP can handle numbers over 65535 by using LONG variables...which you can then split up using the WORD or BYTE modifiers, then store those numbers if needed, or recover them, using the WORD, or BYTE variable modifiers.
    Default and...
    .. is it working with any type of PIC or is this LONG feature limited to a certain type of µcs?
    Roger
    I'm lost.
    Roger ...
    You can store them in temporary variables and send them to EEPROM when you've enough time ...
    WHILE some ADC conversions are running in the background ... for example.
    ah, ... yes, I see ... that needs some ... brain use ???
    just open your PBP "samples" folder and look for "A2D10" ... instead of "ADCIN10"
    Good night, Roger
    Default Aha!
    J'ai ze feeling qu'on me taquine un peu...
    Going to do some searching in the samples then.
    Thanks for the advice.
    Roger
  1. Replies: 4
    Last Post: - 15th April 2009, 01:54
