Interrupt mystery - need some guru help
Results 1 to 40 of 44
    No mystery here...
    Re-read the IOC section in the datasheet...
    Your answer is there...
    xnihilo's Avatar
    xnihilo Guest
    Smile Interrupts
    yes, there are a lot of answers there.
    I'm not a programmer so it requires a lot of efforts for me to program. I'm new with PBP and PICs.
    It's pretty complicated and I'm tired because I work on my project every night till late so I must be missing the point. So if you know the answer, could you help me please.
    Quote Originally Posted by xnihilo View Post
    I'm not a programmer either...just ask anybody around here!
    But you're answer really is in the datasheet, DS41202F, Section 4.2.3
    And if I tell you, then you will have learned but ONE single thing.
    If you figure it out, you'll have begun to understand a number of things...
    xnihilo's Avatar
    xnihilo Guest
    is it because pic sets all ports to input pins upon powerup?
    Mar 2004
    UK-Midlands
    Hi xnihilo,
    skimask has pinpointed the passage in the datasheet that clearly tells you what you need to do before enabling the interrupt and after servicing the interrupt. I appreciate that English is probably not your first language but re-examine the paragraph and what it tells you is required before enabling the interrupt?
    Bob
    xnihilo's Avatar
    xnihilo Guest
    Smile no more riddles, need advises
    Please, no more riddles.
    I beleive the portA has to be read prior to enabling interrupts.
    Are these steps order right?
    - enable weak pullups with OPTION_REG = %01111111 (even if I DON'T know what should be the settings for bits 0 to 6, which seem not useful for me)
    - enable WPU for desired ports, for me it should be: 010111 (no WPU for RA3 which is used as an input port) (no WPU for RA5 which is used with default 0V and is activated when 5V gets to this pin)
    - TRISA = %101111 because all porta pins has to be input except for pin RA4 which is used for R/S bit for an LCD pannel
    - TRISC = %000000 (all output)
    - PORTA.5 = 0 (I set specificaly RA5 to 0 because I want it to be LOW at the start, all other porta pins will be brought high automatically by WPU)
    - PORTC = %000000 (I set all portC pins low)
    - I initialize all my variables
    - I put some stuff here like display on LCD
    - IOCA = %101111 because I enable PORTA change interrupt for all porta pins except for the pin used for LCD R/S bit
    - INTCON = %10001000 (I enable interrupts: GIE and portachange)
    - ON INTERRUPT GOTO myroutine
    Is that correct?
    There's only one riddle...why haven't you read the section I specified earlier?
    It's right there in the datasheet...Section 4.2.3, 2nd paragraph.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
