Interrupt mystery - need some guru help
Results 1 to 40 of 44
    Is there any available schematic of it?
    That's quite an ISR you have.... Usually it has to be kept as short as possible. I'll try having a look at this later.
    Looking at the actual main loop... i'm not even sure if ANY interrupts are needed. Maybe just a read PORTA in a loop would do the job.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    If fact I'm building 4 projects, all used in a lasergame system, one is the sensors module on the player, one is the gun itself, one is the mag (that manages all the bullets and spare mags) and the last one is the supplier for providing spare mgs and medics to players.
    I've debuged the first three modules these 3 last days and I still have to take care of the supplier module.
    All handshaking between pics is not tested yet, for debugginf phase, I preset the values to what's expected as a reply. The gun encodes a PWM signal to represent a header, a byte and a trailer, the sensors module gets the signal, checks structure validity then extracts the byte and use it.
    I hope I won't encounter timing problems with that part.
    Polling quickly portA won't be enough...
    So since then... what's new, something is better worst, code is still the same?
    I hate guessing without schematic i can try and/or double check first...too bad!
    xnihilo's Avatar
    xnihilo Guest
    Smile
    Today I'm finishing the last module: the MAG module.
    When done, I'll update my website with the specs for each system along with the schematics. After that only will it be possible to discuss further, I'll let you know when it is done. Thanks.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
    Last Post: - 6th March 2005, 01:07
