accessing ports pins using an index variable
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default Code sample
    Hello xnihilo,
    You may find some ideas here: http://www.picbasic.co.uk/forum/show...4326#post44326
    HTH
    Roger
    Jan 2006
    Istanbul
    If I am getting it right, this should be it.
    But, this should not be this easy, should it?
    I must be wrong then.
    <font color="#000000">TRISA = <font color="#FF0000"><b>%11111
    </b></font>MyPort <font color="#000080"><b>VAR </b></font>PORTA
    Index  <font color="#000080"><b>VAR BYTE
    </b></font>Start:
        <font color="#000080"><b>FOR </b></font>Index = <font color="#FF0000"><b>0 </b></font><font color="#000080"><b>TO </b></font><font color="#FF0000"><b>5   </b></font><font color="#000080"><i>' Scan MyPort (PORTA) pins.
          </i><b>IF </b></font>MyPort.<font color="#FF0000"><b>0</b></font>[Index] = <font color="#FF0000"><b>0 </b></font><font color="#000080"><b>THEN BRANCH </b></font>Index,[IntA0,IntA1,IntA2,IntA3,IntA4,IntA5]
        <font color="#000080"><b>NEXT </b></font>Index
        <font color="#000080"><i>' Above routine is the same as
        ' IF MyPort.0 = 0 then IntA0
        ' IF MyPort.1 = 0 then IntA1
        ' IF MyPort.2 = 0 then IntA2
        ' IF MyPort.3 = 0 then IntA3
        ' IF MyPort.4 = 0 then IntA4
        ' IF MyPort.5 = 0 then IntA5
    </i><b>GOTO </b></font>Start
    IntA0:
    <font color="#000080"><i>'Do your stuff or PORTA.0 here.
    IntA1:
    <font color="#000080"><i>'Do your stuff or PORTA.1 here.
    IntA2:
    <font color="#000080"><i>'Do your stuff or PORTA.2 here.
    IntA3:
    <font color="#000080"><i>'Do your stuff or PORTA.3 here.
    IntA4:
    <font color="#000080"><i>'Do your stuff or PORTA.4 here.
    IntA5:
    <font color="#000080"><i>'Do your stuff or PORTA.5 here.
    <font color="#000080"><b>END
    </b></font>
    xnihilo's Avatar
    xnihilo Guest
    thank you very much for your help guys
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 00:06
  2. How to index Port variable
    By jpadin1 in forum mel PIC BASIC Pro
    Last Post: - 17th February 2010, 10:36
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  4. Accessing pins with a variable
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 20th August 2004, 16:03
  5. Accessing ports ( Melanie )
    By anj in forum mel PIC BASIC Pro
    Last Post: - 7th March 2004, 20:52
