accessing ports pins using an index variable
Results 1 to 9 of 9
    xnihilo's Avatar
    xnihilo Guest
    Smile accessing ports pins using an index variable
    Hi there,
    I need your help about using PBP pro with a PIC16F684.
    I have to access portA pins in my program, using a variable as an index because I need to check what pin triggered the interrupt and then I need to poll the pin.
    (let's assume the INT triggering port A pin is default high with weak pullups, it goes low when an int occurs and I jump to the below routine once I know what pin triggered the INT and assign that pin number to trigpin variable)
    for i = 0 to 255
    IF porta.trigpin = 1 then exitloop
    PAUSEus 1000
    next i
    exitloop:
    I know that PCPpro refuses to use porta.trigpin or porta[trigpin]
    Thanks a lot
    for i = 0 to 255
        IF porta <> 0 then exitloop
    pause 1
    next i
    exitloop:
    if any pin on porta is set, exit the loop
    xnihilo's Avatar
    xnihilo Guest
    Smile accessing byte's bits
    Okays, thanks.
    However it does not exactly meet my needs:
    Not all pins will be triggered when they go from High to Low.
    My program gets an IR signal on a sensor connected to a PORTA pin and this triggers an INT. In the int routine, I check what pin received the IR signal and then I poll the pin to get a signal that is encoded.
    On pin RA5, I set no WPU because the default state will be 0V and once 5V gets to this pin, it triggers an INT.
    (I'm developping software and hardware for a lasergame).
    Anyway thank you very much for your help.
    You could bitwise xor the read of port A with a saved previous state. Then changed bits would be set. Then you could use a SELECT CASE to do actions if a specific bit is set
    casetest = portA ^ prev_state
    prev_case = portA
    SELECT CASE casetest
    CASE casetest.BIT0
    ( do stuff for bit 0 changes)
    CASE casetest.BIT1
    (do stuff for bit 1 changes)
    etc, etc.
    Tim Barr
    Sep 2005
    Campbell, CA
    If you just need to know which pin changed, you can
    use something like -
    DeltaPortA = OldPortA ^ PortA
    If DeltaPortA > 0 THEN
    OldPortA = PortA
    BitThatChanged = NCD DeltaPortA
    EndIF
    BitThatChanged will have a number from 1-8, corresponding to the bit that changed.
    If more than one changed, the highest-order bit that changed will be in the variable.
    If you need to know ONLY if it went from LOW to HIGH, you can use
    If DeltaPortA > 0 Then
    OldPortA = PortA
    DeltaLowToHigh = DeltaPortA & PortA
    BitThatChangedH = NCD DeltaLowToHigh
    EndIF
    BitThatChangedH will contain the number (1-8) of the highest order bit that changed from low to high.
    You can use the same technique for figuring out which one went from HIGH to LOW.
    Charles Linquist
    Bombay, India
    Quote Originally Posted by xnihilo View Post
    I think you need to use PortA.0[trigPin]
    there's an entire thread dealing with bit handling on PBP
    SWITZERLAND (french speaking)
    Default Code sample
    Hello xnihilo,
    You may find some ideas here: http://www.picbasic.co.uk/forum/show...4326#post44326
    HTH
    Roger
    Jan 2006
    Istanbul
    If I am getting it right, this should be it.
    But, this should not be this easy, should it?
    I must be wrong then.
    <font color="#000000">TRISA = <font color="#FF0000"><b>%11111
    </b></font>MyPort <font color="#000080"><b>VAR </b></font>PORTA
    Index  <font color="#000080"><b>VAR BYTE
    </b></font>Start:
        <font color="#000080"><b>FOR </b></font>Index = <font color="#FF0000"><b>0 </b></font><font color="#000080"><b>TO </b></font><font color="#FF0000"><b>5   </b></font><font color="#000080"><i>' Scan MyPort (PORTA) pins.
          </i><b>IF </b></font>MyPort.<font color="#FF0000"><b>0</b></font>[Index] = <font color="#FF0000"><b>0 </b></font><font color="#000080"><b>THEN BRANCH </b></font>Index,[IntA0,IntA1,IntA2,IntA3,IntA4,IntA5]
        <font color="#000080"><b>NEXT </b></font>Index
        <font color="#000080"><i>' Above routine is the same as
        ' IF MyPort.0 = 0 then IntA0
        ' IF MyPort.1 = 0 then IntA1
        ' IF MyPort.2 = 0 then IntA2
        ' IF MyPort.3 = 0 then IntA3
        ' IF MyPort.4 = 0 then IntA4
        ' IF MyPort.5 = 0 then IntA5
    </i><b>GOTO </b></font>Start
    IntA0:
    <font color="#000080"><i>'Do your stuff or PORTA.0 here.
    IntA1:
    <font color="#000080"><i>'Do your stuff or PORTA.1 here.
    IntA2:
    <font color="#000080"><i>'Do your stuff or PORTA.2 here.
    IntA3:
    <font color="#000080"><i>'Do your stuff or PORTA.3 here.
    IntA4:
    <font color="#000080"><i>'Do your stuff or PORTA.4 here.
    IntA5:
    <font color="#000080"><i>'Do your stuff or PORTA.5 here.
    <font color="#000080"><b>END
    </b></font>
    xnihilo's Avatar
    xnihilo Guest
    thank you very much for your help guys
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. How to index Port variable
    By jpadin1 in forum mel PIC BASIC Pro
    Last Post: - 17th February 2010, 11:36
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Accessing pins with a variable
    By Desterline in forum mel PIC BASIC Pro
    Last Post: - 20th August 2004, 17:03
  5. Accessing ports ( Melanie )
    By anj in forum mel PIC BASIC Pro
    Last Post: - 7th March 2004, 21:52
