Problem with porta.5 on pic 16f873A
Results 1 to 4 of 4
Threaded View
  1. #2
    Without looking at the data sheet, my first guess would be that it has an open collector output and needs a pullup resistor as the result . . .Gotta love those data sheets.
    Edit: Nope portA.4 is open drain. A.5 appears to be a standard I/O, maybe your PIC is damaged, maybe your breadboard is bad. Check the pin with your voltmeter directly on the pin itself.<br> http://www.kirlian-photography.com/video/PIC16F87XA.pdf
  1. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
  2. Replies: 14
    Last Post: - 31st March 2009, 12:04
  3. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 00:39
  4. PIC to PIC communication problem
    Last Post: - 21st June 2007, 03:51
  5. PC - PIC problem...
    By menhwa in forum Serial
    Last Post: - 20th February 2006, 19:57
