Best way to get the square root of a 16/32 bit unsigned integer
Results 1 to 4 of 4
Threaded View
  1. #2
    Quote Originally Posted by sougata View Post
    find the square root of a 16bit number
    Since it's only a 16 bit number, maybe you'd be best off using a lookup table. After all, there are only 255 integer numbers of squares inside of 16 bits...
    EDIT: Whoops! Just saw that the title said 16/32 bit sqrt instead of 16 bit only.
    But...I'd say, same thing still applies. Could easily get the sqrt of the upper 16 bits of the 32 bits using a lookup table. Then depending on the accuracy required, interpolate the lower 16 bits.
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
