Best way to get the square root of a 16/32 bit unsigned integer
Results 1 to 4 of 4
    Feb 2005
    Kolkata-India
    Default Best way to get the square root of a 16/32 bit unsigned integer
    Hi All,
    In one of my implementation of a true RMS voltmeter I used the Mchip technical bulletin TB040 to find the square root of a 16bit number. I was using the ADC in 8bit on a PIC18. I would like the pros to shed some light on a better way dealing with longs sqrt.
    P.S. = Perhaps a better way to measure AC RMS
    Last edited by sougata; - 17th March 2008 at 19:02. Reason: Might be that should be the question
    Sougata
    Quote Originally Posted by sougata View Post
    Since it's only a 16 bit number, maybe you'd be best off using a lookup table. After all, there are only 255 integer numbers of squares inside of 16 bits...
    EDIT: Whoops! Just saw that the title said 16/32 bit sqrt instead of 16 bit only.
    But...I'd say, same thing still applies. Could easily get the sqrt of the upper 16 bits of the 32 bits using a lookup table. Then depending on the accuracy required, interpolate the lower 16 bits.
    Hi, Sougata
    I do not understand your question ...
    TB 040 ALSO deals with 32 bits ...
    Title"16/32 bit Integer Square Root"
    ; *** Author: Ross Fosler ***
    ; *** Applications Engineer ***
    ; *** Microchip Technology Inc. ***
    ; *** Program:sqrt.asm ***
    ; *** This module contains code to perform fast integer ***
    ; *** square root functions on either 16 or 32 bit ***
    ; *** values. ***
    ; *** Last Rev:August 10, 2000 ***
    ; *** Ver 1.00 ***
    Are you looking for faster than that ???
    Feb 2005
    Kolkata-India
    Default Yes a faster one
    Hi Alain,
    I am actually looking for a faster and better way to do it. Cause my system measures 16 channels and does a whole lot of logging housekeeping stuff.
    Sougata
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
    Last Post: - 6th March 2005, 01:07
