problem with input and output (18F452)
Results 1 to 4 of 4
    Mar 2006
    Ankara -Turkey
    Default problem with input and output (18F452)
    I use 18F452 4MGz xt.some of the codes are below.
    I use PORTA ,PORTC and PORTE output.INPUT PORTD.3 INPUT PORTC.6 INPUT PORTC.4
    LCD and keypad working nice but INPUT and OUTPUT ports not working.
    Is there anybody to help me .
    Thanks.
    INCLUDE "KeyPad.bas"
    'Define LCD connections
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTD
    Define LCD_RSBIT 0
    Define LCD_EREG PORTD
    Define LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 4
    DEFINE LCD_RWREG PORTE
    DEFINE LCD_RWBIT 2
    'Define keypad connections
    DEFINE KEYPAD_ROW 4 ' 4 ROW keypad Tuştakımı yatay
    DEFINE KEYPAD_ROW_PORT PORTB ' ROW port = PORTB
    DEFINE KEYPAD_ROW_BIT 4 ' ROW0 = PORTB.4
    DEFINE KEYPAD_COL 4 ' 4 COL keypad Tuştakımı kolon
    DEFINE KEYPAD_COL_PORT PORTB ' COL port = PORTB
    DEFINE KEYPAD_COL_BIT 0 ' COL0 = PORTB.0
    DEFINE KEYPAD_DEBOUNCEMS 100 ' debounce delay = 20 mSec
    DEFINE KEYPAD_AUTOREPEAT 1 ' use auto-repeat feature
    ' Define program variables
    tus var byte ' tus değeri
    sayim VAR word
    ma VAR word
    nm VAR word
    hy VAR word
    sy150 VAR word
    sy40 VAR word
    tyag VAR word
    thacim VAR word
    INTCON2.7 = 0 ' Enable PORTB pullups (18F452)
    ADCON1 = 7 ' PORTA PORTE digital
    TRISC = %00000000
    TRISE.0 = 0
    TRISE.1 = 0
    TRISE.2 = 0
    LOW PORTE.0
    LOW PORTE.1
    LOW PORTE.2' LCD R/W low (write)
    LOW PORTC.0
    LOW PORTC.1
    LOW PORTC.2
    LOW PORTC.3
    LOW PORTC.5
    LOW PORTC.7
    LOW PORTA.0
    LOW PORTA.1
    LOW PORTA.2
    LOW PORTA.3
    LOW PORTA.4
    LOW PORTA.5
    INPUT PORTD.3 'TEMAS TUŞU
    INPUT PORTC.6
    INPUT PORTC.4 ' SİNYAL GİRİŞİ
    Pause 200 ' LCD açılması için bekle
    Birbirimize yardım için buradayız.
    We are here to help each other....
    Feb 2005
    Kolkata-India
    Default Parallel Port setup is wrong perhaps
    Quote Originally Posted by turkuaz View Post
    TRISE.0 = 0
    TRISE.1 = 0
    TRISE.2 = 0
    Use instead
    TRSIE = 0
    PIC18F452 has a parallel port (PMP) similar to a microprocessor bus which uses the TRISE register for the configuration and the PORTE as the control line for the PORTD (PMP) read write. Other bits (7 to 4) are used to configure this.
    Hope this helps
    Sougata
    TrisD = %00001000 ' all port d as outputs except bit 3 input
    TrisC = %01010000 ' all port c outputs except bits 6 and 4 inputs
    TrisA = %00000000 ' all port a as outputs
    TrisB = %11110000 ' lower 4 bits outputs upper inputs
    TrisE = %00000000 ' all 8 bits as outputs
    edit: Sougata undoubtly knows what he is talking about and posted while I was writing.
    Jun 2007
    Sydney, Australia
    And make sure that all your DEFINE statements are in upper case, ie:
    should be
    DEFINE LCD_DREG PORTD
    (Skimask & Bruce pointed this out to me last week!)
    Phil.
  1. LED "capacitance" won't get lower
    Last Post: - 3rd May 2007, 20:31
  2. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 01:50
  3. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
