HSERIN each character cost 3 pgm words
Results 1 to 12 of 12
    Quote Originally Posted by boban View Post
    I think, the EEPROM is not solution it has just 256 bytes and I need to store there some data and also external EEPROM will complicate the design. But maybe for the storage of lot of html code this could be the solution.........
    P.S. I am now thinking about the feature to have the possibility to store the hlml pages during runtime - kind of firmware update. My idea is to reserve the space in code memory like put there spaces and via webserver to have the service to upgrade the html code during the runtime. But I must check the assemler if it is possible to write to program code during the execution. Have no clue....
    Would be a load easier just to add an external 24LCxxx serial eeprom and use that. 2 wires, I2Cread/I2Cwrite... Not much code space wasted, lots of room for add-ons...
    Not much code space in a '916 as you're well aware I'm sure. Start adding HTML code as data in the program space, and you'll be out of space in no time flat...
    Jan 2007
    Default 16f916
    Hello, the external eeprom will complicate the design, and if you are writting effectively html you could store almost 10 K of HTML = 5 K words and remaining 3 k of code, I have managed to store what I wanted. I have just little bit fighted with the fact, that if you are doing something like
    @ da "abcd",10,"efgh",0 the da will pack 0 and 10 and it caused the cutting of my Strings. So I have decided to put to the end of each string not 0 but 0x7F and I have modified little bit the code to skip 0 byte and use 7F as separator. And it is working pretty well!!! Thanks everyone for help!!!
    StringOut:
    ReadCode Addr, TwoChars
    Char = TwoChars >> 7
    if Char = $7F THEN StringDone
    if Char <> 0 then hserout [Char]
    Char = TwoChars & $7F
    if Char = $7F then StringDone
    Addr = Addr + 1
    goto StringOut
    StringDone:
    That'll work!
    Might use a few bytes for those extra 0's
    You can put the "Escape codes" in the string, and it won't use the extra bytes.
    @ da "abcd\nefgh",0
    \a	Bell (alert) character		07
    \b	Backspace character		08
    \f	Form feed character		0C
    \n	New line character		0A
    \r	Carriage return character	0D
    \t  	Horizontal tab character	09
    \v	Vertical tab character		0B
    \\	Backslash			5C
    \?	Question mark character		3F
    \'	Single quote (apostrophe)	27
    \"	Double quote character		22
    \0OO	Octal number (zero, Octal digit, Octal digit)
    \xHH	Hexadecimal number
    Might even be able to put the "Null terminator" in there too.
    @ da "abcd\nefgh\x00"
    But I haven't tried that yet.
    Jan 2007
    Thumbs up xHH versus 0xHH
    Hello Darrel, thanks a this helped I didn't know, taht I could use the escape sequences like in C or Java
  1. Replies: 4
    Last Post: - 15th April 2009, 01:54
  2. HSERIN and STR - character encoding
    By boban in forum mel PIC BASIC Pro
    Last Post: - 13th August 2008, 17:36
  3. Hserin, 1st character always lost!
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 5th June 2007, 12:49
  4. Someone help me to simplify this
    By thrix in forum General
    Last Post: - 21st February 2004, 05:01
  5. Help wanted..
    By thrix in forum mel PIC BASIC Pro
    Last Post: - 17th February 2004, 23:44
