strange problem ! pic18f4550 & pic16f84a serial communication .
Results 1 to 19 of 19
    Jun 2007
    thanks for reply , but when i paste this code i get an error .
    and am sure i setup it to correct frequency .
    error :
    overwriting previous address contents (0000) .
    symbol not previously defined (_fcmem_on_1h) .
    regrads .
    Quote Originally Posted by amenoera View Post
    error :
    I've seen this before somewhere. Don't remember what the deal was.
    Do a search on fcmem and fcmen.
    Should fix you up...
    EDIT: Found it...
    Old versions of MPLAB use FCMEM, new one uses FCMEN
    http://www.picbasic.co.uk/forum/show...m+fcmen&page=3
    Post #82
    Feb 2005
    Essex, UK
    Skimask has given you the answer for the error but the frequency will need to be defined as 48MHz when you correct to FCMEN instead of FCMEM. This is because the config settings I have given you set the PIC to run from 48MHz PLL clock source which is generated by the PIC internally but using your 20MHz crystal as the original clock source.
    Hope this helps. Let us know how you get on.
    Cheers
    Rob
    Jun 2007
    Thumbs up
    woow , yes you are right .
    all i did is :
    1 : for this "symbol not previously defined (_fcmem_on_1h) " error , i changed it
    to "(_fcmen_on_1h" .
    2 : i comment this lines in "18f4550.inc" in my "pbp" folder :
    ; __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    ; __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
    this 2 line is reponsable for this erro "overwriting previous address contents (0000)"
    3 : i change "define osc 20" to "48" .
    after that , all works fine , and i can now send and recive without any problems .
    thanks again .
    regards .
    Feb 2005
    Essex, UK
    Smile
    Excellent,
    glad it's working for you!
    Kind regards
    Rob
  1. Serial Communication Using PIC16F84A
    By fazan83 in forum GSM
    Last Post: - 22nd January 2007, 03:56
  2. Serial Communication Problems (Strange!!)
    By Armando Herjim in forum Serial
    Last Post: - 20th June 2006, 23:46
  3. Replies: 5
    Last Post: - 20th March 2006, 02:34
  4. Serial Communication Problem
    Last Post: - 23rd February 2006, 03:11
  5. Replies: 8
    Last Post: - 11th November 2004, 21:08
