strange problem ! pic18f4550 & pic16f84a serial communication .
Results 1 to 19 of 19
    Oct 2009
    Default Re: strange problem ! pic18f4550 & pic16f84a serial communication .
    Just testing, as sometimes I've noticed that when pasting code copied from MCS into the forum, it sometimes re-formats it and changes upper to lower case
    Just ignore this
    DEFINE  OSC 20                          ' 18F4520, 20mhz crystal
    Edit: - seems to work fine so it's not that, so must be human error ;-)
    In MCS keywords are reformatted on the fly - but for display purposes only. The case in which you type it in is what's stored in the actual file. If you typ HsERiN that's what stored when you save the file even if MCS displays HSERIN on the screen.
    define is a keyword so when you type that in MCS it gets reformatted to upper case (if you have your formatting setup that way) but if you then copy/paste that into Notepad or whatever it reverts to the way you typed it (which can be DefINe or whatever). OSC on the other hand - which is the important thing here - is NOT a keyword that MCS recognizes so it does NOT get reformatted and that's a good thing in this case because if it did you'd see OSC on the screen even if you typed it as osc which would then cause the assembler to not recognize it as OSC.
  1. Serial Communication Using PIC16F84A
    By fazan83 in forum GSM
    Last Post: - 22nd January 2007, 02:56
  2. Serial Communication Problems (Strange!!)
    By Armando Herjim in forum Serial
    Last Post: - 20th June 2006, 22:46
  3. Replies: 5
    Last Post: - 20th March 2006, 01:34
  4. Serial Communication Problem
    Last Post: - 23rd February 2006, 02:11
  5. Replies: 8
    Last Post: - 11th November 2004, 20:08
