the ultrasonic SRF04 with pic16f88
Results 1 to 16 of 16
    Quote Originally Posted by tur_bot View Post
    wasn't that easy to understand the data sheet but because of all of you guys, with all your examples and suggestions , i managed to find the right settings.
    Just curious...which bit fixed the problem?
    Invariably, it's usually that one little bit that fixes everything...
    Mar 2008
    london
    Default which bit fixed the problem
    those 6 lines allowed me to use an accurate inside clock and to use all pins as digital input or outputs:
    INTRC_OSC_NOCLKOUT
    INTRC_IO
    OSCCON=%01101000
    ANSEL=%00000000 'this comand disable all adc
    CMCON=%00000111 'this bit disable all comparators
    the two last commands fixed the problem to get just digital inpout and outpout on all 15 pins available, and disabled all adc and comparators.
    Just like posts #2, #4, #8, #10 said it would...
  1. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 00:13
  2. Replies: 8
    Last Post: - 7th December 2006, 15:42
  3. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 17th September 2006, 23:31
  4. sensor ultrasonic 8051&PIC
    By hd_uni_pro in forum Schematics
    Last Post: - 13th September 2006, 12:58
  5. SRF04 Range Finder 16F628 R18iXL Board
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 02:08
