the ultrasonic SRF04 with pic16f88
Results 1 to 16 of 16
    Mar 2008
    london
    Default the ultrasonic SRF04 with pic16f88
    hello everybody
    I have few problems with my ultrasonic ranger the SRF04.
    I managed to make it work with a pic 16f84 to measure distances in inches and centimeters and display the results on a serial lcd. worked really fine.
    then i tried to use the pic 16f88 with an internal clock ; but the lcd displays 0cm and 0 inches all the time which means that the SRF04 is not doing the job (the internal clock is working by the way. i tested it with another code)
    here is a part of my code in picbasic pro:
    INTRC_OSC_NOCLKOUT
    INTRC_IO
    OSCCON=%01101000
    include "modedefs.bas"
    trisa = %11111111
    trisb = %00000000
    lcd var portb.7
    'piezo var portb.4
    trigger var portb.6
    echo var porta.0
    baud con N2400
    dist_raw var word
    dist_inch var word
    dist_cm var word
    conv_inch con 15
    conv_cm con 6
    low trigger
    serout lcd,baud,[254,1] 'clear lcd screen
    serout lcd,baud,[254,128,"-sonar ranger-"]
    'sound piezo,[100,10,50,5,70,10,50,2] 'make startup sound
    pause 1000 'pause 1 sec
    serout lcd,baud,[254,128,"inches: "] 'set up the lcd display
    serout lcd,baud,[254,192,"centimeters: "]
    gosub sr_sonar
    serout lcd,baud,[254,135,#dist_inch," "] 'display the disance in inches
    serout lcd,baud,[254,204,#dist_cm," "] 'display the distance in cm
    sr_sonar:
    pulsout trigger,1 'send a 10us trigger pulse
    pulsin echo,1,dist_raw 'start timing the pulse width
    'on echo pin
    dist_inch = (dist_raw/conv_inch)
    dist_cm = (dist_raw/conv_cm)
    pause 1
    i suppose that the pins of the pic are not inputing or outputing the right datas. may be because i did not set the input and output properly.
    i had been strogling for few days , please help me to make it work.
    thanx
    regards
    Just an idea ...
    May be some comparators and adc to disable ???
    Good evening
    Mar 2008
    london
    Red face how ??
    good idea but how can I do it???
    how can I disable the ADC and comparators in a 16f88???
    Oct 2003
    holland
    There could be a possibility to find that kind of information in the datasheet.
    I did that for all types I use and it worked !!
    Mar 2008
    london
    Default datasheet
    hi
    i just tested my port with few led and they work fine, inputing and outputting.
    but the srf04 is still not working.
    I have no idea of what is going on.
    anybody with an idea????
    - Try External clock !!! ( internal Osc is "not so accurate" ...)
    - Place "Low trigger" just before "Pulsout"
    Muaz's Avatar
    Muaz Guest
    Hi, This post of mine is very knowledgable and may enhance the information of the viewers , however I would like some specific information for myself. If someone can help me then please send me a private message. Best Regards,
  1. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
  2. Replies: 8
    Last Post: - 7th December 2006, 16:42
  3. PIC16F88 problem with TOGGLE command?
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 18th September 2006, 00:31
  4. sensor ultrasonic 8051&PIC
    By hd_uni_pro in forum Schematics
    Last Post: - 13th September 2006, 13:58
  5. SRF04 Range Finder 16F628 R18iXL Board
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 03:08
