I2C slave
Results 1 to 4 of 4
Thread: I2C slave
    Hi Charles,
    If I get this correctly you are sending out and receiving on the same PIC . . .
    MeThinks that isn't going to work because by the time it gets around to receiving
    the info the output has already sent it. . . Now I maybe totally wrong. Have you tried using 2 PICs?
    Sep 2005
    Campbell, CA
    I am sending and receiving on the same PIC. I'm sending using PBP bit-banging and I'm receiving using the hardware. Unless I'm mistaken, when I send a byte out using I2CWRITE, the hardware should grab it and set PIR1.3.
    Anyway, I have done the same thing using SEROUT and HSERIN. That works.
    BTW: I noticed that I had ADCON1 set to "0". I changed it to $FF (all digital) and it still doesn't work.
    Charles Linquist
    Hi Charles,
    I never thought that would work, ' have to give that a try.
    Cheers
    JS
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Another I2C Slave Routine Problem
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 06:50
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
