I2C slave
Results 1 to 4 of 4
Thread: I2C slave
    Sep 2005
    Campbell, CA
    Default I2C slave
    I'm trying to make an I2C slave using some code I found in this forum originally
    written for the 16F series.
    I'm using an 18F8722 and as you can see, I'm trying a "loopback" technique where
    I'm sending data using I2CWRITE and trying to receive it using the hardware I2C port.
    PORTF.3 is connected to PORTC.4 and
    PORTF.5 is connected to PORTC.3
    Both have 4.7K pull-ups.
    Some LEDs are connected to PortD. The code loops, but PIR1.3 is never set.
    Does anyone know what I should try next? The code is below.
    SDAS VAR PORTF.3
    SCLS VAR PORTF.5
    TRISC = %10111111
    TRISD = %00000000
    TRISF = %11111111
    ADCON1 = 0 ; No analog
    HSEROUT ["Alive",13,10]
    PORTD = 0 ' Shut off all LEDs
    SSP1STAT.7 = 1 ' Low speed mode
    SSP1STAT.6 = 0 ' Disable SMBbus-specific inputs
    ' Define used register flags
    SSPIF VAR PIR1.3 ' SSP (I2C) interrupt flag
    BF VAR SSP1STAT.0 ' SSP (I2C) Buffer Full
    R_W VAR SSP1STAT.2 ' SSP (I2C) Read/Write
    D_A VAR SSP1STAT.5 ' SSP (I2C) Data/Address
    CKP VAR SSP1CON1.4 ' SSP (I2C) SCK Release Control
    SSPEN VAR SSP1CON1.5 ' SSP (I2C) Enable
    SSPOV VAR SSP1CON1.6 ' SSP (I2C) Receive Overflow Indicator
    WCOL VAR SSP1CON1.7 ' SSP (I2C) Write Collision Detect
    ' Define VARs and types
    datain VAR BYTE ' Data in
    counter1 VAR BYTE
    I2Caddress VAR BYTE
    ' Initialize I2C slave mode
    I2CAddress = $0
    SSPADD = I2caddress ' Set our address
    SSPCON1 = %00110110 ' I2C slave with 7-bit address
    ' PIE1.3 = 1 ' SSP (I2C) interrupt enable '- don't need Ints for this test
    ' INTCON.6 = 1 ' PEIE = Peripheral Interrupt Enable bit
    ' INTCON.7 = 1 ' GIE enable
    SSPIF = 0
    SSPSTAT = $00
    mainloop:
    HSEROUT ["."] ' Indicate we are doing something
    IF SSPIF THEN
    SSPIF = 0 ' clear the flag
    datain = SSPBUF
    SSPBUF = datain
    CKP = 1
    GOSUB Blink5 ' let me know that i2c receive occurred
    I2CWRITE SDAS,SCLS,$0,$0,[$55] ; Send some data, any data
    PAUSE 2000
    GoTo mainloop ' Do it forever
    Blink5:
    For counter1 = 1 to 5
    PORTD = $FF
    PAUSE 100
    PORTD = 0
    PAUSE 100
    NEXT Counter1
    Charles Linquist
    Hi Charles,
    If I get this correctly you are sending out and receiving on the same PIC . . .
    MeThinks that isn't going to work because by the time it gets around to receiving
    the info the output has already sent it. . . Now I maybe totally wrong. Have you tried using 2 PICs?
    Sep 2005
    Campbell, CA
    I am sending and receiving on the same PIC. I'm sending using PBP bit-banging and I'm receiving using the hardware. Unless I'm mistaken, when I send a byte out using I2CWRITE, the hardware should grab it and set PIR1.3.
    Anyway, I have done the same thing using SEROUT and HSERIN. That works.
    BTW: I noticed that I had ADCON1 set to "0". I changed it to $FF (all digital) and it still doesn't work.
    Charles Linquist
    Hi Charles,
    I never thought that would work, ' have to give that a try.
    Cheers
    JS
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Another I2C Slave Routine Problem
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 06:50
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
