I'm trying to make an I2C slave using some code I found in this forum originally
written for the 16F series.
I'm using an 18F8722 and as you can see, I'm trying a "loopback" technique where
I'm sending data using I2CWRITE and trying to receive it using the hardware I2C port.
PORTF.3 is connected to PORTC.4 and
PORTF.5 is connected to PORTC.3
Both have 4.7K pull-ups.
Some LEDs are connected to PortD. The code loops, but PIR1.3 is never set.
Does anyone know what I should try next? The code is below.
SDAS VAR PORTF.3
SCLS VAR PORTF.5
TRISC = %10111111
TRISD = %00000000
TRISF = %11111111
ADCON1 = 0 ; No analog
HSEROUT ["Alive",13,10]
PORTD = 0 ' Shut off all LEDs
SSP1STAT.7 = 1 ' Low speed mode
SSP1STAT.6 = 0 ' Disable SMBbus-specific inputs
' Define used register flags
SSPIF VAR PIR1.3 ' SSP (I2C) interrupt flag
BF VAR SSP1STAT.0 ' SSP (I2C) Buffer Full
R_W VAR SSP1STAT.2 ' SSP (I2C) Read/Write
D_A VAR SSP1STAT.5 ' SSP (I2C) Data/Address
CKP VAR SSP1CON1.4 ' SSP (I2C) SCK Release Control
SSPEN VAR SSP1CON1.5 ' SSP (I2C) Enable
SSPOV VAR SSP1CON1.6 ' SSP (I2C) Receive Overflow Indicator
WCOL VAR SSP1CON1.7 ' SSP (I2C) Write Collision Detect
' Define VARs and types
datain VAR BYTE ' Data in
counter1 VAR BYTE
I2Caddress VAR BYTE
' Initialize I2C slave mode
I2CAddress = $0
SSPADD = I2caddress ' Set our address
SSPCON1 = %00110110 ' I2C slave with 7-bit address
' PIE1.3 = 1 ' SSP (I2C) interrupt enable '- don't need Ints for this test
' INTCON.6 = 1 ' PEIE = Peripheral Interrupt Enable bit
' INTCON.7 = 1 ' GIE enable
SSPIF = 0
SSPSTAT = $00
mainloop:
HSEROUT ["."] ' Indicate we are doing something
IF SSPIF THEN
SSPIF = 0 ' clear the flag
datain = SSPBUF
SSPBUF = datain
CKP = 1
GOSUB Blink5 ' let me know that i2c receive occurred
I2CWRITE SDAS,SCLS,$0,$0,[$55] ; Send some data, any data
PAUSE 2000
GoTo mainloop ' Do it forever
Blink5:
For counter1 = 1 to 5
PORTD = $FF
PAUSE 100
PORTD = 0
PAUSE 100
NEXT Counter1
