LCD serial
Results 1 to 11 of 11
Thread: LCD serial
    Mar 2008
    Question LCD serial
    Hi to everybody,
    I use a serial LCD Devantech 4 xes 20 one wire connected to the usual pic.
    When it begins working strange things to the characters happen: they appear of of it new, they skip in low they disappear then then aloft, it returns normal for a certain time, it illuminates him jerky when he is not programmed to light up.. What can the cause be?
    thanks
    chip_select
    skimask's Avatar
    skimask Guest
    Not following your english very well.
    Could you give a shot at rephrasing this a bit?
    Mar 2008
    Default lcd serial
    the display involves in strange way. it is unstable. characters that disappear or that are replaced. example:
    'my code :
    include "modedefs.bas"
    loop:
    serout portb.0,2,[" Good morning"]
    serout portb.0,2,[12,1] 'clear display
    goto loop
    'the display
    second: 1 2 3
    Good moxxx g āoox morǼinx 17od morninx and so on..
    skimask's Avatar
    skimask Guest
    Are you using the internal oscillator on the PIC? Might not be as stable as you think...
    Also, try adding some CHAR_PACING (it's in the manual)...at 9600 baud, 5ms should be more than enough to keep a serial LCD happy.
    Past that, try bumping down to 2400 baud and see what happens...
    Mar 2005
    Iowa, USA
    Why are you writing to it, and then in the next line of code, clearing the screen? .... Then looping through the same sequence???
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Is this the display you are using?
    http://www.robot-electronics.co.uk/htm/Lcd02tech.htm
    Mar 2008
    Smile lcd solved
    THX SKIMASK,
    I have added : "define char_pacing 5 "
    Now it works fine.
    chip_select
    Sep 2003
    Vermont
    So there is a baud rate speed mismatch between the PIC and the LCD. What oscillator speed/config are you using?
    Mar 2008
    Default lcd
    Or INTOSC or Crystal 4Mhz whit 2 capacitor 22pF.
    Mar 2008
    Default lcd
    T9600 baud
    What chip?
    Can you post your whole code?
    And post how your fuses are set. Either from the *.inc or in code or if you are using one of those programs that does it for you.
  1. LCD serial backpacks
    By Archangel in forum Serial
    Last Post: - 30th December 2010, 05:51
  2. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Serial LCD
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 09:31
  5. Need help with LCD number display.
    Last Post: - 27th June 2007, 00:07
