Bluetooth problme with the 16F877A
Results 1 to 7 of 7
    Quote Originally Posted by slimpeng View Post
    DEFINE debug_mode 0 ' Debug sending True serial data
    DEFINE debug_reg Portc ' Debug Port = PortC
    DEFINE debug_bit 6 ' Debug.bit = PortC.6
    DEFINE debug_baud 9600 ' Default baud rate = 9600
    define loader_user 1
    Let me guess...if you can't get this code to work...something will happen, right? What could that something be
    http://www.picbasic.co.uk/forum/showthread.php?t=7953
    No need to double post!!!
    CAPS! CAPS! CAPS!!! DEFINEs need to be in CAPS just like the book says!
    Not that it has anything to do with your problem...
    Still trying this on a simulator?
    Isn't this project about overdue by now? After all, it is for school, right?
    Read the manual (and other relevant datasheets) concerning your use of N9600 and a MAX232...
    Do you still expect to read a sensor with ADCIN and have it be magically converted from voltage to C?
    Seriously though...if you can't make the project work without the bluetooth module, how do expect it to work WITH the bluetooth module...
    Small steps...tiny tiny tiny small steps...build it up from nothing to the finished product...
    Jan 2008
    yup this is my school project...i finish ADC part ad...result also get it...now the problme is why the pic cant communicat with bluetooth module one and i very blur ad...if using RF module can get the result......if using bluetooth cant why...
    if the source code problme or other thing problme....
    help it....pls........
    (SIGH...)
    Or....
    Jan 2008
    i read ad the data sheet .....but still got problme......now i got 2 bluetooth module ...one bluetooth module connet to pc with the MAX232 without any PIC and another one bluetooth with the PIC 16F877A so on the PIC there i send out the temperature data to bluetooth and bluetooth Tx to Rx bluetooth at PC there so....why the Rx part bluetooth cant get my data or communicate with the bluetooth one...???? Is the PIC problem or programming problem ?
    on the PIC 16F877A i set the comment is "SEROUT PORTC.6,N9600,[#temp,13,10]
    and the PC there i using hyperterminal to test it...at there i set the baudrate 115200 the hyperterminal can communicate with my bluetooth. so now only cant communicate with my PIC 16F877A so help it ......????
    if i using the USB bluetooth can ply around with the bluetooth module with the max232 on the PC part......!!! so can u tell me wat the problme with the PIC thanks u all....!!!!
    Jan 2008
    why so selffish one de.......about that is school project one u all no want to help people ad......i very upsad.........at here ad.......!!!! if we knw how to do it...also no come here to asking and asking ad.........
  1. interaction between Bluetooth and PIC MCU
    By veenadari in forum Bluetooth
    Last Post: - 23rd June 2009, 16:03
  2. help my bluetooth and PIC 16F877A?
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 07:52
  3. RS232 to blue tooth modules
    By isaac in forum Bluetooth
    Last Post: - 14th March 2008, 14:00
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. Bluetooth wireless with PIC / HSERIN / DAC
    By rpatel in forum mel PIC BASIC Pro
    Last Post: - 20th December 2004, 23:13
