Adjusting PWM frequency
Results 1 to 9 of 9
    May 2007
    Suffolk, UK
    Hi Roger
    I'm pretty new to this as well but I'd like a shot at answering your question. If I'm wrong I get shot down as well!
    Freq Calc
    PWM freq = Fosc/(PR2 + 1) x 4 x Prescale
    With PR2 at 249 this is 4,000,000/250 x 4 x 4 = 1000 Hz.
    Your 255 gives 4,000,000/256 x 4 x 4 = 976.56Hz which is what you measured.
    Resolution formula as you stated. With PR2 at 249 then Resolution is Log 4 x 250/Log2 = 9.9657 = 1000 bit resolution (999.94 actually)
    With PR2 ar 255 then resolution will be Log 4 x 256/Log2 = 10 bit but your frequency then can't be 1kHz ...only 976 Hz
    Hope I got this all OK guys
    Adrian
    Quote Originally Posted by Adrian View Post
    Looks good to me...and it's also the reason why you'll never get exactly 1khz at 4mhz...
    PR2 = 249 = 976.56hz
    PR2 = 248 = 1004.0160642570281124497991967871 Hz
    SWITZERLAND (french speaking)
    Thumbs up Thanks a lot
    It's very clear now.
    Thanks for your explanations.
    Roger
    It's a bit confusing...
    The FREQ of the PWM can only be (X) and you might not be able to set it to (X+1) because the 'setter' of the FREQ is a divisor of Fosc. The duty cycle of that particular frequency of the PWM can be practically anything.
    There are other ways to get an exact PWM frequency with an exact duty cycle at that exact frequency...but they go quite a bit further than a standard PIC.
  1. SLA battery charging with PWM but which frequency
    By showtime in forum mel PIC BASIC Pro
    Last Post: - 13th June 2017, 11:41
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 07:24
  4. PWM - Dutycycle affecting frequency?
    Last Post: - 18th May 2007, 09:32
  5. inaccurate frequency using TMR1 PI18F452
    By nkarpovich in forum mel PIC BASIC Pro
    Last Post: - 14th October 2006, 16:22
