Correct!My understanding was that the INT_INT was for RB0 (external Int) only and that RBC_INT was for the "change on RB 4-7".
Steve had found that bug later in the thread. I forgot to mention it.
It should be RBC_INT.
Hi All,
Been banging my head for a while now and I am getting closer. Thank you for the time you have taken to add life to this forum.
The Travel encoder section works pretty well, but the Manual encoder is erratic and sometimes take over the travel section and not let it work. A bump on Manual, and the Travel works again.
As a reminder. The Travel generates Pulse and Direction in one direction only. The Manual is for bi-directional fine adjustment after the Travel section's movement is complete (automatic). Target: 12F675 @ 4mHz INT_OSC
Anybody see what I'm missing?
Bo
Code:A_trav VAR GPIO.0 'Travel encoder A input B_trav VAR GPIO.1 'Travel encoder B input A_man var GPIO.2 'Manual Encoder A input B_man var GPIO.3 'Manual Encoder B input P_out var GPIO.4 'Pulse output to motor D_out var GPIO.5 'level output for direction Dir VAR bit 'Direction Scratch var byte 'dummy byte Old_Bits VAR BYTE New_Bits VAR BYTE TravEncOld var byte 'TRAVel Measurement ENCoder TravEncNew Var byte ' ManEncOld var byte 'MANual input ENCoder ManEncNew var byte ' P_out = 1 'servo I/P = LO pulse, start HI INTCON = %10001000 'GLOBAL ON, GPIO Int ON CMCON = 7 'Comparator off, Digital I/O OPTION_REG = %00000000 'GPIO Pull-up Enabled TRISIO = %001111 WPU = %000111 'pull-ups 0-2 (3 added on board) IOC = %001111 'Int On Change GPIO 1-3 ANSEL = 0 INCLUDE "DT_INTS-14-0.bas" '..-14-0 = ALL Banks REM'd ASM INT_LIST macro ; IntSource, label, Type, ResetFlag? INT_Handler RBC_INT, _EncChg, ASM, yes endm INT_CREATE ; Creates the interrupt processor INT_ENABLE RBC_INT ;RB Port Change Interrupt ENDASM Old_Bits = GPIO & (%001111) 'Get initial inputs Main: GOTO Main '---[RBC - interrupt handler]--------------------------------------------------- EncChg: New_Bits = GPIO & (%001111) 'Get inputs TravEncNew = New_Bits & (%000011) 'strip New Travel encoder TravEncOld = Old_Bits & (%000011) 'Strip Old Travel Encoder if TravEncNew = TravEncOld then ManEnc ' If no chg -> Manual Encoder Dir = TravEncNew.1 ^ TravEncOld.0 'Check direction D_out = Dir 'Direction LEVEL out if Dir = 1 then 'Only travel 1 direction pulsout P_out,20 'drive servo controller Endif 'Controller is STEP/DIRECTION I/P goto DoneRotEnc 'skip Manual Encoder ManEnc: ManEncNew = New_Bits & (%001100) 'strip Manual Encoder ManEncOld = Old_Bits & (%001100) Dir = ManEncNew.3 ^ ManEncOld.2 'Direction of Manual input D_out = Dir pulsout P_out,20 'Pulse for either direction DoneRotEnc: Old_Bits = New_Bits 'reset reference Scratch = GPIO 'read GPIO to clear mis-match @ INT_RETURN
The interrupt type should be PBP.And you'll need to INCLUDE "ReEnterPBP.bas", for it to work.Code:ASM INT_LIST macro ; IntSource, label, Type, ResetFlag? INT_Handler RBC_INT, _EncChg, PBP, yes endm
I need to point out that this in on a 12F675.
I commented out the bank lines in DT_INTS-14 (hence the "DT_INTS-14-0.bas" on the include)
and removed ReEnterPBP
I tried to use things in the way that was discussed in http://www.picbasic.co.uk/forum/show...9510#post49510
Does that help this make sense a bit more?
Bo
Yes it does.
Since you don't have anything in the Main loop, you can probably get away with it.
But the PULSOUT statement uses PBP system vars. So if you add anything to the the Main loop, something will need to be changed.
I'm wondering how you got past the GPIF/GPIE problem. Should have been something like this ...As for the main problem, the only thing I can see that might cause it is the Scratch = GPIO at the end of the handler.Code:ASM RBIF = GPIF RBIE = GPIE INT_LIST macro ; IntSource, label, Type, ResetFlag? INT_Handler RBC_INT, _EncChg, ASM, yes endm
The mismatch is cleared in the first line New_Bits = GPIO & (%001111)
Reading it again at the end of the handler, may be causing it to miss changes on the port. Try commenting it out.
Still looking.
Back to this project.
Imagine a sewing machine. When the needle goes down, the thread is held steady and travels with the needle. When the needle goes up, the thread is fed out at the same rate that it travels up, feeding slack. There is a servo motor with an encoder feeding the thread and a matching encoder reading the travel distance and speed. There is also an aux encoder (ManDrive) that can be used to retract or feed the thread to trim or allow for excess so you can cut the thread. The manual feed/trim works as expected, but after a manual encoder change, sometimes the travel feed operates on both directions of input from the travel encoder instead of just retract. The feed is the correct direction, but when bad, the "down" feeds at twice the input rate while the "up" feeds normally. A change on the Man encoder allows it to work correctly again.
Anyone care to take another look?Code:' 1) Quadrature encoder reading direction and speed of mechanical slide. ' 2) Motor (servo) driven in ONE direction of slide movement, ' not driven for other direction. Pulse & Direction drive LOW. ' 3) Manual Encoder to drive servo either direction manually. ' ADD pull-up to GPIO.3 on 12F675 ' DEBUG splash on power-up on GPIO.5 ' 12F675 ' -----------u---------- ' -|Vdd(+) (-)Vss |- ' D_out -|GP5 GP0/PGD|- A_trav ' P_out -|GP4 GP1/PGC|- B_trav ' B_man -|GP3/MCLR/Vpp GP2/INT|- A_man ' ---------------------- DEFINE DEBUG_REG GPIO DEFINE DEBUG_BIT 5 DEFINE DEBUG_BAUD 2400 ' DEFINE DEBUG_MODE 0 DEFINE OSC 4 clear A_trav VAR GPIO.0 ' Travel encoder A input B_trav VAR GPIO.1 ' Travel encoder B input A_man var GPIO.2 ' Manual Encoder A input B_man var GPIO.3 ' Manual Encoder B input P_out var GPIO.4 ' PULSE output to motor, Active LOW D_out var GPIO.5 ' LEVEL output for direction AutoCnt var word 'preprogrammed feed @ end of cycle Dir VAR byte 'Direction EncOld var byte EncNew var byte ManCnt var byte 'Counter for recent Man Pulses TrvCnt var byte ' Travel Encoder before change INTCON = %10001000 ' GLOBAL ON, GPIO Int ON CMCON = 7 ' Comparator off, Digital I/O OPTION_REG = %00000000 ' GPIO Pull-up Enabled TRISIO = %001111 WPU = %11111111 ' weak p/u on 0-2,4,5, GPPU must be enabled for p/u IOC = %00001111 ' Interrupt on Change for GPIO: 0-3 ANSEL = 0 ' Analog off ManCnt = 0 TrvCnt = 0 P_out = 1 ' start out HI. Moves on LOW pulse INCLUDE "DT_INTS-14-0.bas" 'Base Inturrupt program:0 banks 'include "ReEnterPBP-0.pbp" 'allow PBP int ASM RBIF = GPIF RBIE = GPIE INT_LIST macro ;IntSource, Label, Type, ResetFlag? INT_Handler RBC_INT, _EncChg, ASM, yes endm INT_CREATE ;creates the INT processor INT_ENABLE RBC_INT ;enable RB change int ENDASM debug "LW-FiberDrive-7" Main: ManualDrive: ' MANUAL first: set direction bit if ManCnt > 0 then Dir = EncNew.3 ^ EncOld.2 ' XOR new L bit > Old Rt bit=Direction D_out = Dir 'set direction pin pauseus 2 P_out = 0 'send drive pulse either dir pauseus 2 P_out = 1 'reset drive pulse ManCnt = ManCnt - 1 ' empty out pulse counter endif D_out = 1 'set direction pin TravelDrive: D_out = 1 'set direction pin if TrvCnt > 0 then Dir = EncNew.1 ^ EncOld.0 ' XOR new L bit > Old Rt bit=Direction If DIR = 0 then TravDown 'end if travel DOWN pauseus 2 P_out = 0 'send drive pulse retract only pauseus 2 P_out = 1 'reset drive pulse TravDown: TrvCnt = TrvCnt - 1 endif goto main '++++++++ Motor Drive Pulse Out interrupt handler ++++++++++++++++++ EncChg: 'got here if GPIO 0-3 changed EncOld = EncNew EncNew = GPIO if (EncNew & (%00001100)) = (EncOld & (%00001100))then ' man enc same? TrvCnt = TrvCnt + 1 ' trav moved: count travel interrupts endif ManCnt = ManCnt + 1 ' else: Man moved:count man interrupts @ INT_RETURN end
HI all,
I'm in the process of moving this over to a larger PIC so that I can have a chance to get some debugging info out of it. I have some 16F627's that will run at 20MHz instead of the 12F675 @ 4MHz. That will allow some HSEROUT data to give me a better look at what's happening and some headroom in the speed area. Thought I could just whip this one out, but alas, too big for my pants again...
Bo
