Instant Int and encoder (Elect. Gearing)
Results 1 to 14 of 14
    Pay no attention to the man behind the curtain. (or was that a mask)
    With DT_INTS, nothing is "blocking" except the interrupt handlers themselves.
    DOH!!! no kidding...
    Feb 2008
    Michigan, USA
    Thanks for the replys Darrell and Skimask.
    I so hate asking for help for something thats likely to be an oversight on my part. I don't ever want to abuse the list's willingness to help.
    I'm going through your suggestions and the first thing that I don't understand in http://www.picbasic.co.uk/forum/showthread.php?p=25396 is this:
    INT_Handler INT_INT, _Rot_Encoder, PBP, yes
    @ INT_ENABLE RBC_INT ;RB Port Change Interrupt
    My understanding was that the INT_INT was for RB0 (external Int) only and that RBC_INT was for the "change on RB 4-7".
    I'm going to test and try to answer my own question, but I thought it should be answered in print. I know I have spun in small circles after looking for stuff like this.
    Bo
    Correct!
    Steve had found that bug later in the thread. I forgot to mention it.
    It should be RBC_INT.
    Feb 2008
    Michigan, USA
    Default Progress, but not right yet...
    Hi All,
    Been banging my head for a while now and I am getting closer. Thank you for the time you have taken to add life to this forum.
    The Travel encoder section works pretty well, but the Manual encoder is erratic and sometimes take over the travel section and not let it work. A bump on Manual, and the Travel works again.
    As a reminder. The Travel generates Pulse and Direction in one direction only. The Manual is for bi-directional fine adjustment after the Travel section's movement is complete (automatic). Target: 12F675 @ 4mHz INT_OSC
    Anybody see what I'm missing?
    Bo
    A_trav  VAR GPIO.0          'Travel encoder A  input
    B_trav  VAR GPIO.1          'Travel encoder B  input
    A_man   var GPIO.2          'Manual Encoder A input
    B_man   var GPIO.3          'Manual Encoder B input
    P_out   var GPIO.4          'Pulse output to motor
    D_out   var GPIO.5          'level output for direction
    Dir         VAR bit            'Direction
    Scratch     var byte            'dummy byte
    Old_Bits    VAR BYTE
    New_Bits    VAR BYTE
    TravEncOld  var byte            'TRAVel Measurement ENCoder
    TravEncNew  Var byte            '
    ManEncOld   var byte            'MANual input ENCoder
    ManEncNew   var byte            '
    P_out = 1                   'servo I/P = LO pulse, start HI
    INTCON = %10001000          'GLOBAL ON, GPIO Int ON
    CMCON =  7                   'Comparator off, Digital I/O
    OPTION_REG = %00000000      'GPIO Pull-up Enabled
    TRISIO = %001111
    WPU = %000111               'pull-ups 0-2 (3 added on board)
    IOC = %001111               'Int On Change GPIO 1-3
    ANSEL = 0
    INCLUDE "DT_INTS-14-0.bas"     '..-14-0 = ALL Banks REM'd
    INT_LIST  macro    ; IntSource,    label,  Type, ResetFlag?
            INT_Handler    RBC_INT,  _EncChg,   ASM,  yes
        INT_CREATE                   ; Creates the interrupt processor
    Old_Bits = GPIO & (%001111)                 'Get initial inputs
    GOTO Main
    '---[RBC - interrupt handler]---------------------------------------------------
    EncChg:
        New_Bits = GPIO & (%001111)                'Get inputs
        TravEncNew = New_Bits & (%000011)          'strip New Travel encoder
        TravEncOld = Old_Bits & (%000011)          'Strip Old Travel Encoder
        if TravEncNew = TravEncOld then ManEnc   ' If no chg -> Manual Encoder
        Dir = TravEncNew.1 ^ TravEncOld.0            'Check direction
        D_out = Dir                                  'Direction LEVEL out
        if Dir = 1 then                              'Only travel 1 direction
        pulsout P_out,20                             'drive servo controller
        Endif                                'Controller is STEP/DIRECTION I/P
        goto DoneRotEnc                      'skip Manual Encoder
    ManEnc:
        ManEncNew = New_Bits & (%001100)           'strip Manual Encoder
        ManEncOld = Old_Bits & (%001100)
        Dir = ManEncNew.3 ^ ManEncOld.2           'Direction of Manual input
        D_out = Dir
        pulsout P_out,20                        'Pulse for either direction
    DoneRotEnc:
         Old_Bits = New_Bits                    'reset reference
         Scratch = GPIO                         'read GPIO to clear mis-match
    @ INT_RETURN
    The interrupt type should be PBP.
            INT_Handler    RBC_INT,  _EncChg,   PBP,  yes
    And you'll need to INCLUDE "ReEnterPBP.bas", for it to work.
    Feb 2008
    Michigan, USA
    I need to point out that this in on a 12F675.
    I commented out the bank lines in DT_INTS-14 (hence the "DT_INTS-14-0.bas" on the include)
    and removed ReEnterPBP
    I tried to use things in the way that was discussed in http://www.picbasic.co.uk/forum/show...9510#post49510
    Does that help this make sense a bit more?
    Bo
    Quote Originally Posted by boroko View Post
    Yes it does.
    Since you don't have anything in the Main loop, you can probably get away with it.
    But the PULSOUT statement uses PBP system vars. So if you add anything to the the Main loop, something will need to be changed.
    I'm wondering how you got past the GPIF/GPIE problem. Should have been something like this ...
    RBIF = GPIF
    RBIE = GPIE
    As for the main problem, the only thing I can see that might cause it is the Scratch = GPIO at the end of the handler.
    The mismatch is cleared in the first line New_Bits = GPIO & (%001111)
    Reading it again at the end of the handler, may be causing it to miss changes on the port. Try commenting it out.
    Still looking.
  1. Using PICBASIC PRO in MPLAB IDE
    By jblackann in forum General
    Last Post: - 4th May 2008, 10:20
