Rotary Hex Dip Switch Code???
Results 1 to 2 of 2
    Feb 2008
    Unhappy Rotary Hex Dip Switch Code???
    Can someone give me an idea what the code should look like for reading this type of rotary dip switch. I've looked everywhere and can't find any examples in PBP. The tech. sheets with the switch isn't much help either. I'm using a 16f690 chip and the switch is connected to the 4 port B pins.
    Dan
    Perth, Australia
    This is how I would do it:
    - Connect the common (C) pin to +5v
    - Connect the 4 other pins to PORTB.4-PORTB.7
    - Use 10k resistors to pull each of those pins to ground.
    Now all you have to do is this:
    some_variable = ( PORTB & $F0 ) >> 4
    now, some_variable should be equal to the position of your switch.
  1. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 18:51
  2. HARDWARE I2C SAMPLE CODE question
  3. Making Program Code Space your playground...
  4. Rotary encoders
    By mister_e in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 16:57
  5. need hex code to make 12c509 a flip flop,
    By bruce3mn in forum General
    Last Post: - 15th November 2004, 03:23
