12f629
Results 1 to 11 of 11
Thread: 12f629
    Omaha, Nebraska USA
    Question 12f629
    It looks like I'm going to be using a 12F629 for an application.
    Any warnings/surprises/secrets and/or obscure aspects I should be aware of?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Hi Russ,
    I have been using the 675 quite a bit lately and getting used to GPIO.X instead of PORT?.X is my only problem.
    Jan 2006
    Istanbul
    Quote Originally Posted by RussMartin View Post
    We are using thousands of F629 in a month.
    The only issue we have is with the chip's eeprom. Most of the time, the eeprom is not good.
    So, we return lots of them; and this is time consuming.
    When we use F675, we do not get any bad eeprom issue.
    So, if you have lots of "write" routines in your application, I would say, go with F675.
    F675 is more expensive then F629 ( for us it is; for some other is does not matter).
    Mar 2008
    Texas, USA
    Be sure to turn off the analog comparators if you don't want them. Default has them turned on.
    sayzer, that's odd. I don't use thousands a month, but I do use hundreds a month. I use the eeprom area quite aggressively and so far (knock on wood) I have yet to find an eeprom issue with the 12F629's. This is what I make and sell: http://www.york-electronics.com/
    Talking
    Hi, "JD123"
    I think I've seen that gadget somewhere else ... but Where ??? ( LOL !!! )
    Welcome here , Gary !
    PS : Those 12F629 are a Very Special Turkish batch ... like Sayzer's programmer ... ( a Special Turkish copy of the K149 from Kits'r us ... )
    Mar 2008
    Texas, USA
    Hi Alain,
    Yep, I'm not know for being 'under cover' for very long.
    I wish I was named JD... who in their right mind thinks of "Gary" when they name their kids?
    Mar 2008
    Texas, USA
    LOL! I just caught this. LOL
    Talking
    Quote Originally Posted by JD123 View Post
    Hi Alain,
    What about Gary Gliter ???
    Not so bad ...
    Mar 2008
    Texas, USA
    Wink
    Not so bad ...
    Okay, I have to admit... it could be worse.
    Omaha, Nebraska USA
    Thumbs up
    Thanks for the information, folks!
    It looks like I need a single analog port now, so I'll probably graduate to the 675.
    Russ
    Wink
    Hi, Russ
    If your Analog measurements are ... not so precise, or slow ...comparators AND the trimmable voltage ref , or the RCTime function can do it ...
    Without any ADCs ...
  1. Input problems with 12F629?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th April 2018, 06:25
  2. 12F629 LDR - Light Dependant Resistor
    By Dennis in forum Schematics
    Last Post: - 18th February 2010, 22:33
  3. 12f629 config settings
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 22:39
  4. Basic help for 12F629
    By Gene Choin in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 04:06
  5. Servo control with 12F629
    Last Post: - 23rd June 2005, 23:34
