Surviving 1 second without battery power
Results 1 to 28 of 28
    Feb 2005
    You know...I was thinking...
    In this type of project, there's nothing that says the PIC has to turn itself completely off right away.
    Why can't it stay running for, say 10 seconds, after the LED is powered off.
    So, the process looks like this:
    Initial power on with an initial mode...
    LED lit, PIC waiting...
    button pressed, LED off, PIC still waiting...
    If one second passes without a button press, the PIC shuts itself off.
    If a button press happen inside of one second, the mode changes and the 1 second timer is reset.
    Requires a bit more thought with the single button power on/off circuit, but that's easy...
    This is the circuit Im using:
    With this code:
    @ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off, bod_on
    CMCON0 = %00000111     ' Disable comparator
    VRCON  = %00000000     ' disable
    '       I/Os
    TRISIO = %00000000      ' no inputs
    ' definitions
    ' init values
    if PCON.0=0 then
      gpio=%00000100        'Brown-out detected turn on LED on PIN5 (red)
      gpio=%00000010        'Brown-out NOT detected turn on LED on PIN6 (green)
    'main loop
    loop:
    pcon.0=1
    goto loop
    It does not work, the minute I give it power green lits and after 5 seconds¿?¿? it goes off and red lits.
    Am I missing something?
    I can use a 12F675 or even a 12F683 if a simpler / more efficient solution is possible.
    Regarding flashlight operation, think of a flashlight without buttons, it goes on or off by twisting the body, and the battery electrical path to the LED/uC is done using the metal body. So this means when power is gone, is gone for everything. To be even more clear, here is a CAD drawing of my latest creation:
    The green you see there is the uC/driver PCB that also serves as positive contact for the battery. Ground is attached inside the flashlight head.
    To check more flashlights check: www.neoca.com.ar Thanks!
    Hi, Peu
    You're out ...
    '@ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off, bod_on
     @    __config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _WDT_ON &_BOD_ON & _MCLRE_OFF & _CP_OFF
    OSCCON = %01100110
    ADCON0 = %11100000
    ANSEL  = %10000000
    '       I/Os
    gpio   = %00000000
    BOD var GPIO.0
    POR var GPIO.1
    IF PCON.1 = 0 and PCON.0 = 0 THEN BOD = 1	'BROWN OUT RESET BIT
    IF PCON.1 = 0 				 THEN POR = 1	'POWER ON RESET BIT
    PAUSE 1000
    GPIO = 0
    if PCON.1 = 1 AND PCON.0 = 0 then		'PCON.0 = BOD ;PCON.1 = POR
        GPIO.2 = 1         'GPIO.1 red led PIN6 shows a BOD state
        PAUSE 5000
        PCON.0 = 1
        gpio = %00000000
    PCON.1 = 1
    PCON.0 = 1
    While 1
    Wend
    This works really fine, but with a 10 µ (MICRO) F ...and a 12F683
    so , some current draw improvements are still to add ...
    NOTE: All Outputs are Mosfet Buffered ( BS 170 ) ...
    PS: You didn't use your brain too much, here ....
    Change your test circuit as follows:
    Put a diode between the cap and the battery disconnect point like the sample schematic at the beginning of this thread has. This will isolate the PIC power from the rest of the circuit so that the cap will power the PIC when the battery is disconnected.
    Connect the LED cathodes to the I/O pins. Then connect the LED anodes to the battery disconnect point between the battery and the diode that was added above. By doing this, the LEDs won't draw power once the battery is disconnected.
    Tim Barr
    Feb 2005
    Quote Originally Posted by peu View Post
    [edit] Maybe I need to check for POR=1 and BOD=0 to know for sure that a BOD reset happened
    I wasn't that far with this late edit
    What brain?
    Well I implemented your program and it worked, but the cap value was way too high, so I started lowering till I found a ridiculously low value...
    Then I examined your code, removed some chunks and commented it:
    ' I use picbasic to compile!!
     '@    __config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _WDT_ON &_BOD_ON & _MCLRE_OFF & _CP_OFF
    OSCCON = %01100110
    ADCON0 = %11100000
    ANSEL  = %10000000
    '       I/Os
    gpio   = %00000000
    ' SECTION? what is this section used for?
    ' BOD var GPIO.0
    ' POR var GPIO.1
    ' IF PCON.1 = 0 and PCON.0 = 0 THEN BOD = 1	'BROWN OUT RESET BIT
    ' IF PCON.1 = 0 THEN POR = 1	'POWER ON RESET BIT
    ' PAUSE 1000  this pause cannot be used in a flashlight environment
    GPIO = 0
        GPIO.2 = 1          'GPIO.2 green led PIN6 shows a BOD state
        PAUSE 1000          'I don't have patience :-)
        'PCON.0 = 1         ' not needed since you set this again below
        gpio = %00000000
    'PCON.1 = 1      replaced with one line :-)
    'PCON.0 = 1
    PCON=%00000011
    GPIO.1 = 1 'normal state red led
    While 1
    Wend
    and if a picture is a 1000 words, we could say that a video is like 1000 pictures, so 1000x1000=1000000 words... WOW... I just wrote a book take a look at this video: http://www.veoh.com/videos/v6415763hQHpjMDy
    As you see, the cap is reaaally small, the green led shows BOD condition, and red led is normal operation. The diode you see there is not used. Also I left all the unused pins floating
    When I used large value capacitors, everytime I did a power interruption no matter if it was 1 second or 10 the BOD led turned on.
    I wonder why you had to use 10uF
    Also assembled a proto PCB using the 1st schematic to start testing a real world application.
    Talking
    What brain?
    " Whose brain ??? " could have been good level humour ...
    << ' I use picbasic to compile!! >>
    Me too !!! ... did you notice a little difference between MPLAB and Microcode studio ???
    << I wonder why you had to use 10uF >>
    I don't know ... gives me a ~ .3 s power interrupt delay ... and it won't be my headache !!!
    The Pic itself draws .77 mA ...
    Feb 2005
    Alain, I just sent you a Private Message.
    [edit] Sorry for the missunderstanding, and thanks for your reply
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
