Im reading different PIC datasheets so shed some light about the BOD sequence, but most of them share the same wording, Im really lost.
I made a little proggie to test what I've learned in this thread, but it does not work, maybe Im missing something stupid, but after many hours of trying, maybe what I need is a good rest:
then the schematic is pretty simple, a ceramic capacitor at the power lines for storing some battery, a couple of leds at the specified pins and a momentary switch that allows me to cut VDD for a moment.Code:@ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off, bod_on CMCON0 = %00000111 ' Disable comparator VRCON = %00000000 ' disable ' I/Os TRISIO = %00000000 ' no inputs ' definitions BODD var PCON.0 gpio=%00000100 'I know program cold started pause 1000 'gpio.2 green led pin5 indicates coldstart gpio=%00000000 loop: if BODD=0 then gpio=%00000010 'GPIO.1 red led PIN6 shows a BOD state pause 1000 gpio=%00000000 BODD=1 endif goto loop
It does not vork
[edit] Maybe I need to check for POR=1 and BOD=0 to know for sure that a BOD reset happened
Help!![]()
Here is the best reason ( may be others ... I must check ) for your gadget not to work ...
THE DEVICE MUST DRAW AS LITTLE CURRENT AS POSSIBLE !!!
Your led leads VCC voltage to ZERO ... so ... POR and not BOR !!!
Rest helped clear my mind
I will test this code as soon I arrive at my office:
I can't imagine simpler code to test the BOD function. Do you see something wrong?Code:@ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off, bod_on CMCON0 = %00000111 ' Disable comparator VRCON = %00000000 ' disable ' I/Os TRISIO = %00000000 ' no inputs ' definitions ' init values if PCON.0=0 then gpio=%00000100 'Brown-out detected turn on LED on PIN5 else gpio=%00000010 'Brown-out NOT detected turn on LED on PIN6 endif 'main loop loop: goto loop
Was not so easy ... but finally got it !!!
all the trick is in the bits setting and testing scheduling ... Always keep in mind the processor will re-start from the beginning.
Have fun ... the ( let's be modest ! ... A ) working listing waits for your first try ...
Other trick : May be you'll have to test greater values capacitors ...
You know...I was thinking...
In this type of project, there's nothing that says the PIC has to turn itself completely off right away.
Why can't it stay running for, say 10 seconds, after the LED is powered off.
So, the process looks like this:
Initial power on with an initial mode...
LED lit, PIC waiting...
button pressed, LED off, PIC still waiting...
If one second passes without a button press, the PIC shuts itself off.
If a button press happen inside of one second, the mode changes and the 1 second timer is reset.
Requires a bit more thought with the single button power on/off circuit, but that's easy...
Hi, Ski
My tries show the processor runs in a Low Power mode ...
Your solution is easy with the ADC (or a comparator ! ) instead of the BOR ... But the goal was NOT TO USE an adc.
I know ... a '675 doesn't cost so much more than a '629.
Just consider it was another forum " for the fun contest" !!!
This is the circuit Im using:
With this code:
It does not work, the minute I give it power green lits and after 5 seconds¿?¿? it goes off and red lits.Code:@ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off, bod_on CMCON0 = %00000111 ' Disable comparator VRCON = %00000000 ' disable ' I/Os TRISIO = %00000000 ' no inputs ' definitions ' init values if PCON.0=0 then gpio=%00000100 'Brown-out detected turn on LED on PIN5 (red) else gpio=%00000010 'Brown-out NOT detected turn on LED on PIN6 (green) endif 'main loop loop: pcon.0=1 goto loop
Am I missing something?
I can use a 12F675 or even a 12F683 if a simpler / more efficient solution is possible.
Regarding flashlight operation, think of a flashlight without buttons, it goes on or off by twisting the body, and the battery electrical path to the LED/uC is done using the metal body. So this means when power is gone, is gone for everything. To be even more clear, here is a CAD drawing of my latest creation:
The green you see there is the uC/driver PCB that also serves as positive contact for the battery. Ground is attached inside the flashlight head.
To check more flashlights check: www.neoca.com.arThanks!
