Surviving 1 second without battery power
Results 1 to 28 of 28
    Feb 2005
    So you've got a counter...that counts...and it sits there...counting...
    when the power button is pushed...
    If the count < x then it saves the next mode and powers down
    If the count > x then it doesn't switch modes in eeprom and just powers down
    But you must count while the power is out... there is no backup power. The mode is changed if you do an ON-OFF-ON cycle in less than a second.
    I Just updated the schematic to clearly show the entire circuit is battery powered with no backup power, reload the image so the new one is shown.
    Maybe Im missing something from your answer <scratching head>
    Wink
    Quote Originally Posted by peu View Post
    YES !!!
    The capacitor holds enough power to the PIC not to reset all registers While you do the "quick on-off-on"
    remember V b.o.r. is more than the min running voltage of the Pic ... and driving your current sinks do not drain much current from the PIC ...
    so that gives enough time for the Pic to reset AND test the BOR Bit, change the mode, ... ... after that you re-apply the power ...
    Héhé ...
    Ok, I smell what your cooking...
    Put a meter on the cap and see what it reads and how fast it decays.
    Maybe it's a version of a super-cap in a really small package.
    PIC's (nano-watt PIC in particular) can draw some seriously LOW current in a sleep mode.
    Feb 2005
    I think I understand what you guys mean, this would be the metacode
    set BODEN config bit to 1
    set BOD bit to 1
    set POR bit to 1
    read level from eeprom / set level
    mainloop
    check for BOD/POR bits at PCON register
    if BOD=0 then wait for POR=0 and change to next level and write it to eeprom.
    goto mainloop
    Is this correct?
    I have some questions:
    What would happen if power is lost while writing to eeprom?
    Can this be handled with PBP without using interrupts?
    Regarding the cap, I don't have a oscilloscope to see the discharge curve, it seems to last around 1seg to fall below 2v but this measurement was done by the eyemeter.
    Lightbulb
    Hi, Peu
    NO, you did not understand ...
    1) You enable BODEN, nothing else required ...
    2) AT program start, you first read the BOR bit
    3) If BOR Bit = 0 THEN (and only IF ) you increase the EEPROM content : That means power is back, and did not reach ZERO !!! ( no Pb to write , then ...)
    4) If BOR Bit = 1 power has gone to ZERO ( and BOR bit has been reset ) ... just read the EEPROM content .
    5) you SET BOR bit
    6) you run your "lighting" program ...
    Think simple !!!
    Last edited by Acetronics2; - 12th March 2008 at 20:55. Reason: BOR Electrical levels inverted ...
    Feb 2005
    KISS principle... I know... Im getting older&rusty (just crossed the 40 mark).
    Will give your post explanation a try in real code and let you know. Thanks!
    Feb 2005
    Hi, Peu
    3) If BOR Bit = 1 THEN (and only IF ) you increase the EEPROM content : That means power is back, and did not reach ZERO !!! ( no Pb to write , then ...)
    4) If BOR Bit = 0 power has gone to ZERO ( and BOR bit has been cleared ) ... just read the EEPROM content .
    5) you run your "lighting" program ...
    Think simple !!!
    Im kinda lost again:
    From TABLE 9-6: INITIALIZATION CONDITION FOR SPECIAL REGISTERS
    PCON is initialized with %00000010 (POR=1 BOD=0)
    From 2.2.2.6 PCON Register
    REGISTER 2-6: PCON — POWER CONTROL REGISTER (ADDRESS: 8Eh)
    bit 0 BOD: Brown-out Detect STATUS bit
    1 = No Brown-out Detect occurred
    0 = A Brown-out Detect occurred (must be set in software after a Brown-out Detect occurs)
    From these datasheet entries I dont understand when BOD goes to 1
    Talking
    Do not worry !!!
    sooo ... just use the Bit level corresponding to what happend ! ... invert BOR levels I indicated for 3) and 4) and you'll have it ...
    I've correct the thread , NOW ... I had not used that feature for a while ...
    << Im getting older&rusty (just crossed the 40 mark). >>
    ... and me the 51 Mark !!!
    Feb 2005
    Hi, Peu
    5) you SET BOR bit
    Think simple !!!
    I still have a doubt: when does the BOD bit goes from the initialization value ZERO (table 9-6) to ONE (No Brown-out Detect occurred) in a cold start scenario?
    At cold start the circuit should read the stored eeprom value not write a new one
    Feb 2005
    Im reading different PIC datasheets so shed some light about the BOD sequence, but most of them share the same wording, Im really lost.
    I made a little proggie to test what I've learned in this thread, but it does not work, maybe Im missing something stupid, but after many hours of trying, maybe what I need is a good rest:
    @ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off, bod_on
    CMCON0 = %00000111     ' Disable comparator
    VRCON  = %00000000     ' disable
    '       I/Os
    TRISIO = %00000000      ' no inputs
    ' definitions
    BODD var PCON.0
    gpio=%00000100            'I know program cold started
    pause 1000                'gpio.2 green led pin5 indicates coldstart
    gpio=%00000000
    loop:
    if BODD=0 then
        gpio=%00000010        'GPIO.1 red led PIN6 shows a BOD state
        gpio=%00000000
        BODD=1
    goto loop
    then the schematic is pretty simple, a ceramic capacitor at the power lines for storing some battery, a couple of leds at the specified pins and a momentary switch that allows me to cut VDD for a moment.
    It does not vork
    [edit] Maybe I need to check for POR=1 and BOD=0 to know for sure that a BOD reset happened
    Help!
    Thumbs down
    Here is the best reason ( may be others ... I must check ) for your gadget not to work ...
    THE DEVICE MUST DRAW AS LITTLE CURRENT AS POSSIBLE !!!
    Your led leads VCC voltage to ZERO ... so ... POR and not BOR !!!
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
