Surviving 1 second without battery power
Results 1 to 28 of 28
    It might not have to survive without power.
    If you power up, read a byte from eeprom, you can know what mode you were in last time around, increment that value, then power down.
    Next time you power up, you read the same byte, the mode has incremented, save the value, power down...wash lather rinse repeat.
    And there's probably some slick single-button power on/off trickery going on.
    Do a search and you'll find a slick single-button power on/off trickery circuit here too...
    Feb 2005
    Thanks for your prompt reply Skimask (as always I must add )
    If you power up say after 10 seconds it remembers the last mode, but if you do an ON-OFF-ON cycle in less than a second it changes modes as described. Thats the only way to change modes, fast ON-OFFs
    No button trickeries, just fast ON-OFFs I have the driver at hand, and this technique is rather common in new multimode LED flashlights.
    I know how to do it by using an extra diode and a PIC pin to detect power lost, but this circuit uses a more efficient way for doing that.
    Quote Originally Posted by peu View Post
    So you've got a counter...that counts...and it sits there...counting...
    when the power button is pushed...
    If the count < x then it saves the next mode and powers down
    If the count > x then it doesn't switch modes in eeprom and just powers down
    Talking The good question ...
    Is it a Power on Reset
    or
    Is it a Brown Out Reset ...
    Just test the PCON bits ... to know it. and do what's to do.
    But if it's one of those single button power on/off type circuits, it'll always be a power on reset.
    Feb 2005
    But you must count while the power is out... there is no backup power. The mode is changed if you do an ON-OFF-ON cycle in less than a second.
    I Just updated the schematic to clearly show the entire circuit is battery powered with no backup power, reload the image so the new one is shown.
    Maybe Im missing something from your answer <scratching head>
    Wink
    YES !!!
    The capacitor holds enough power to the PIC not to reset all registers While you do the "quick on-off-on"
    remember V b.o.r. is more than the min running voltage of the Pic ... and driving your current sinks do not drain much current from the PIC ...
    so that gives enough time for the Pic to reset AND test the BOR Bit, change the mode, ... ... after that you re-apply the power ...
    Héhé ...
    Ok, I smell what your cooking...
    Put a meter on the cap and see what it reads and how fast it decays.
    Maybe it's a version of a super-cap in a really small package.
    PIC's (nano-watt PIC in particular) can draw some seriously LOW current in a sleep mode.
    Feb 2005
    I think I understand what you guys mean, this would be the metacode
    set BODEN config bit to 1
    set BOD bit to 1
    set POR bit to 1
    read level from eeprom / set level
    mainloop
    check for BOD/POR bits at PCON register
    if BOD=0 then wait for POR=0 and change to next level and write it to eeprom.
    goto mainloop
    Is this correct?
    I have some questions:
    What would happen if power is lost while writing to eeprom?
    Can this be handled with PBP without using interrupts?
    Regarding the cap, I don't have a oscilloscope to see the discharge curve, it seems to last around 1seg to fall below 2v but this measurement was done by the eyemeter.
    Lightbulb
    Hi, Peu
    NO, you did not understand ...
    1) You enable BODEN, nothing else required ...
    2) AT program start, you first read the BOR bit
    3) If BOR Bit = 0 THEN (and only IF ) you increase the EEPROM content : That means power is back, and did not reach ZERO !!! ( no Pb to write , then ...)
    4) If BOR Bit = 1 power has gone to ZERO ( and BOR bit has been reset ) ... just read the EEPROM content .
    5) you SET BOR bit
    6) you run your "lighting" program ...
    Think simple !!!
    Last edited by Acetronics2; - 12th March 2008 at 20:55. Reason: BOR Electrical levels inverted ...
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 15:23
