Surviving 1 second without battery power
Results 1 to 28 of 28
Threaded View
  1. #26
    Feb 2005
    Quote Originally Posted by peu View Post
    [edit] Maybe I need to check for POR=1 and BOD=0 to know for sure that a BOD reset happened
    I wasn't that far with this late edit
    This works really fine, but with a 10 µ (MICRO) F ...and a 12F683
    so , some current draw improvements are still to add ...
    NOTE: All Outputs are Mosfet Buffered ( BS 170 ) ...
    PS: You didn't use your brain too much, here ....
    What brain?
    Well I implemented your program and it worked, but the cap value was way too high, so I started lowering till I found a ridiculously low value...
    Then I examined your code, removed some chunks and commented it:
    @ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off, bod_on
    ' I use picbasic to compile!!
     '@    __config _INTRC_OSC_NOCLKOUT & _PWRTE_ON & _WDT_ON &_BOD_ON & _MCLRE_OFF & _CP_OFF
    OSCCON = %01100110
    CMCON0 = %00000111     ' Disable comparator
    VRCON  = %00000000     ' disable
    ADCON0 = %11100000
    ANSEL  = %10000000
    '       I/Os
    gpio   = %00000000
    TRISIO = %00000000      ' no inputs
    ' SECTION? what is this section used for?
    ' BOD var GPIO.0
    ' POR var GPIO.1
    ' IF PCON.1 = 0 and PCON.0 = 0 THEN BOD = 1	'BROWN OUT RESET BIT
    ' IF PCON.1 = 0 THEN POR = 1	'POWER ON RESET BIT
    ' PAUSE 1000  this pause cannot be used in a flashlight environment
    GPIO = 0
    if PCON.1 = 1 AND PCON.0 = 0 then		'PCON.0 = BOD ;PCON.1 = POR
        GPIO.2 = 1          'GPIO.2 green led PIN6 shows a BOD state
        PAUSE 1000          'I don't have patience :-)
        'PCON.0 = 1         ' not needed since you set this again below
        gpio = %00000000
    'PCON.1 = 1      replaced with one line :-)
    'PCON.0 = 1
    PCON=%00000011
    GPIO.1 = 1 'normal state red led
    While 1
    Wend
    and if a picture is a 1000 words, we could say that a video is like 1000 pictures, so 1000x1000=1000000 words... WOW... I just wrote a book take a look at this video: http://www.veoh.com/videos/v6415763hQHpjMDy
    As you see, the cap is reaaally small, the green led shows BOD condition, and red led is normal operation. The diode you see there is not used. Also I left all the unused pins floating
    When I used large value capacitors, everytime I did a power interruption no matter if it was 1 second or 10 the BOD led turned on.
    I wonder why you had to use 10uF
    Also assembled a proto PCB using the 1st schematic to start testing a real world application.
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 14:23
