Ghange code from PIC16F877A to PIC16F88
Results 1 to 3 of 3
    Jun 2006
    Default Ghange code from PIC16F877A to PIC16F88
    I have the below code.
    I use pic16f877a and work fine. When i use the pic16f88 the code is not work.Why;
    ' Define ADCIN parameters
        DEFINE  ADC_BITS        10     	' Set number of bits in result
        DEFINE  ADC_CLOCK       3     	' Set clock source (3=rc)
        DEFINE  ADC_SAMPLEUS    50    	' Set sampling time in uS
        adval   VAR WORD				' Create adval to store result
        ANSEL = %00000001           'this added for pic16f88
        CMCON = 7                       ' Turn off the comparator
        ADCON0 = %11100001	            ' Configure and turn on A/D Module
        ADCON1 = %10000010              ' Port A is analog
        TRISA = %11111111		        ' Set PORTA to all input
        INCLUDE "LCDbar_INC.bas"        ' Include the BARgraph routines
    loop:
        ADCIN 0, adval					' Read channel 0 to adval (0-1023)
        adval = (adval */ 500)>>2		' equates to: (adval * 500)/1024
        LCDOut $fe,1
        @         BARgraph  _adval,  1,   0,    16,   100,  lines
        PAUSE 200
        GoTo loop       				' Do it forever
    ADCON1 doesn't look right for the '88
    Jun 2006
    I change the ADCON1 and now work.
    Thank you
  1. Ghange code picbasic
    Last Post: - 21st June 2011, 16:16
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Replies: 8
    Last Post: - 7th December 2006, 15:42
