Where should I discuss SD/MMC FAT issues?
Results 1 to 40 of 93
    If _Variable is a CONSTANT, it will work indeed. You can still declare it on asm level
    @MyVar=.30
    and later call the macro
    NOP?C MyVar+10
    That's what I meant...a CONSTANT...
    I think this little tidbit is going to save me a bunch of typing soon...
    In this case, it could be better to change it too.
    NOP?C   macro Cin
        local a
    a=0
        while a<(Cin+MyByte)
            nop
    a++=1
            endw
    and at the top of your code you define MyByte like
    @MyByte=.10 ; your value.. whatever
    Mar 2008
    Texas, USA
    When you first typed "=.30", I thought the decimal and the zero were a type-o. Then I see you used "=.10". It's been a long time (close to 10 years ago) that I've been through the MPASM manual, and I can still go back and read it, but can you explain the "=.30" and "=.10" for defining 3 and 1? I would have thought it would just be "=3" or "=1".
    Thanks for taking your time to explain all this to us.
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    It's just a MPASM naming convention. Depending the current MPASM radix setting
    @a=10
    @B=30
    Those above could be considered as decimal or hexa.
    Let's open a PBP .INC file, let's say 16F628.inc, you'll discover...
            LIST
            LIST p = 16F628, r = dec, w = -302
            INCLUDE "P16F628.INC"   ; MPASM  Header
            ;__config _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    so every value should be considered as decimal using PBP.
    .10 or d'10' will always be considered as 10 decimal whatever your Radix setting is.. kinda safe way to write things.
    Mar 2008
    Texas, USA
    Thanks Mr.E. Now that you mentioned it, I remember dealing with the radix before, but never much explored it many uses. Again, that was a long time ago... and I've had several beers since then.
    oh... think we ALL had few beer... in case you're thirsty
  1. Reading and Writing from SD/MMC cards as FAT filesystem?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2006, 23:26
