Might even work with a separate variable...as in...
@ NOP?C _variable
? maybe? maybe not?
then you could set the variable at the top and only change it once and in your code use something like
@ NOP?C _variable+2
or
@ NOP?C _variable+10
and so on...
But then again, if you go that far, all you're doing is reinventing the wheel (i.e. pauseus)
