Where should I discuss SD/MMC FAT issues?
Results 1 to 40 of 93
    Great! But you where wrong about the 9Tcy... Read previous post again... or build an ASM project then watch the Program Memory window.
    And yet again, that's what I get for posting off the hip... Since when is a macro...a subroutine? Must forgive my blatent stupidity...the house payment is due today
    So, does that little @ NOP?C trick work any other little way that I'm not knowing of yet with anything else?
    BTW...Self-Expanding Macro is my new buzzword...
    Well i don't know.. i'm not in your own short
    When you call a Macro, the compiler just copy/paste the whole macro code where you called the macro.
    let see...
    OneMacro  macro
        MOVE?CT 1,PORTA,0
        MOVE?BB _MyVar,_YourVar
    EACH TIME you call the macro like this...
    @ OneMacro
    This will paste
        MOVE?CT 1,PORTA,0
    so...
    @ OneMacro
    @ OneMacro
    will obviously generate
        MOVE?CT 1,PORTA,0
        MOVE?CT 1,PORTA,0
    Hence why we often suggest to reduce your macro size.
    in NOP?C, The Conditional While (not sure if conditional or MPASM directive.. but anyway), just copy the amount of NOP you asked in the argument parameter
    NOP?C 5
    will juste paste
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    @ NOP
    that's it. No code overhead, no nothing.... self expanding... or expandOnDemand ... huh?
    Mar 2008
    Texas, USA
    Ok, now it's clear and I understnad why it's 5 Tcy for the example. Though it's still going to load tons of NOP's in the code (for my program), it's still strait line. Like you said, it sure will reduce the time needed to tweek the NOP's for clocking speed adjustments. Excelent tip and thanks!
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
    Quote Originally Posted by JD123 View Post
    Might even work with a separate variable...as in...
    @ NOP?C _variable
    ? maybe? maybe not?
    then you could set the variable at the top and only change it once and in your code use something like
    @ NOP?C _variable+2
    or
    @ NOP?C _variable+10
    and so on...
    But then again, if you go that far, all you're doing is reinventing the wheel (i.e. pauseus)
    If _Variable is a CONSTANT, it will work indeed. You can still declare it on asm level
    @MyVar=.30
    and later call the macro
    NOP?C MyVar+10
    That's what I meant...a CONSTANT...
    I think this little tidbit is going to save me a bunch of typing soon...
  1. Reading and Writing from SD/MMC cards as FAT filesystem?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2006, 23:26
