Where should I discuss SD/MMC FAT issues?
Results 1 to 40 of 93
    Quote Originally Posted by JD123 View Post
    For giggles and grins I formatted the MMC as FAT32 and tried to work with the FAT. Let's just say... NOT! I'll stick with FAT16 as long as I can. Does Vista allow FAT16 and or format media cards in FAT16? Thought I heard somewhere that FAT16 support was dropped.
    In that document, it specifies the cluster count cutoff for determining if something is formatted in FAT12/16/32.
    If FAT16 was dropped, I would infer that FAT12 would've been dropped, which means no more floppies at all.
    If you read that document, FAT32 is easy to work with, just have to take heed of the differences. The thing that's a real pain is the long filename's that come with it. But if you ignore those and stick with 8.3, FAT32 is a piece of cake.
    Default MMC specification - free
    Mar 2008
    Texas, USA
    Thumbs up
    Quote Originally Posted by BrianT View Post
    Thanks Brian. I have a copy of that. It reads like the USA budget passed by Congress :0 I couldn't find any information about FAT in the doc, though it may be in there.
    Last night I decided to see if I could find a file armed only with the file name. I was able to do it. I started to write a post that cuts to the chase in explaining how I find a file but decided if I was going to get up in the morning, I'd have to finish it later. I'll post it when it's finished. It will be a real time saver for the first-time MMC user.
    In short, I only need to read a few items from the MBR, Partition Record and the Directory Table (I think that's all I was reading - it was late). It's not hard once I know what to look for and stay within the structure of the FAT.
    It's only an MMC document.
    I forget, do you have the FAT spec's document? (fatgen103?)
    Mar 2008
    Texas, USA
    Skimask, yes. I have the one you were talking about and about 10 other pages found on the net. Together it's concise.
    Thanks again for the LSB information. As I worked last night, I come to find out that all Word and Dword data that points to an address or its offset are written this way in FAT. I never have used the SWAP function of PBP before, but it's coming in very handy right now.
    {4 data bytes, LSB first} D,C,B,A
    swap A, D
    swap B, C
    {4 data bytes, MSB first} A,B,C,D
    I understand this is just a work-around for the fact that "I" work with Word & Dword addresses as MSB first. I'm stuck in my ways... what can I say!
    Mar 2008
    Texas, USA
    Oh, and for what it's worth, I just ordered some FRAM chips from Mouser. That should speed up sector reading a bit. I got 64K's so I can have up to 16 sectors or 4 clusters in RAM at one time. Since it will be so fast (up to 1mhz), I might use it to hold other data too. Having bigger and faster memory is like buying a Ford Excursion after owning a VW Rabbit.
    Mar 2008
    Texas, USA
    Okay, the F-RAM chip is in place and working. Taking all delays out of the code I can get a sector (517 bytes) of the MMC onto the F-RAM in about 13.5ms (MMC > PIC > I2C). That's much faster than the old I2C. It's nice not having to stop and write the buffer page!
    I'm still looking for a faster way to move the I2C data line, so I'm writing my own I2C handler routines. My whole program cycle has to fit into 16.67ms. It doesn't look like I'll be able to load the I2C with sample data then move it to the MMC in this window unless I can get the program cycle, minus the data captures, down to about 6ms. It's going to be close.
  1. Reading and Writing from SD/MMC cards as FAT filesystem?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2006, 22:26
