Hardware I2C
Results 1 to 22 of 22
Thread: Hardware I2C
    Quote Originally Posted by Kamikaze47 View Post
    Do you think it still run at 400kHz by default with a 48Mhz OSC?
    If they don't, set I2C_SLOW and see what happens.
    I don't have access to the macro's here with me, but checking the I2C macros might show whether or not the timing is compensated for with the various oscillator DEFINE's.
    Perth, Australia
    I cant make much sense of the macros, but i'll just see what happens.
    Still waiting for the EEPROM chip to be delivered, but figured I can make a start on my code anyway.
    I know I've been able to get a regular ol' 24LC256 working without a problem at 40Mhz.
    Before you start writing code (and failing! ), be sure to do a search here for the '512 types. There's a couple of small issues that seem to trip people up a lot.
    Perth, Australia
    I've been reading the posts about it, and getting a pretty good idea of where to look if it doesn't work first time. I've written a test program just to write 32 bytes to the EEPROM and then read it back and check against the original data. Now just gotta wait for the chip to arrive.
    One thing I did notice is that people are saying you have to wait 10mS between writing and reading. Does this also apply to just reading? i.e. If I read 32 bytes with [STR string\32] and then do the same thing again to read the next 32 bytes, will I have to wait 10mS between? I'm sure this info must be in the data sheet, but i looked thru the data but couldnt work it out.
    Only applies to the write. If you're using PBP 2.50a, also use the DEFINE that shuts off interrupts during writes.
    Use 10mS as a starting point for the 'after write' delay and make sure it all works fine.
    Then start backing off your delay until it fails, then bump it up a notch. You could get really picky and use pauseus for the delay.
    But I'd say poll the eeprom's busy bit itself for maximum performance.
    As far as multiple byte writes, depends on the eeprom. If the eeprom's page size is 32 bytes, then you write 32 bytes, wait 10mS, write 32, wait 10mS...etc...
    Perth, Australia
    I'm glad that this only applies to writes, because in this particular application the PIC wont need to write to the EEPROM at all. I will fill it with data 1st, and the PIC will only need to read the data, not write it. So looks like I dont have to worry about timing. I'll just read the data whenever I need it.
    That only works with Writes to Internal EEPROM.
    Has no effect on I2CWRITE.
    'der....
    I knew that....
  1. Hardware I2C
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2022, 11:53
  2. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
