I2CRead/I2CWrite can be as fast as the PIC and/or device can make use of them...
Same thing with SerIn/SerOut...if the PIC is set up to run fast and the device can run just as fast, they don't take up much time.
The I2C commands won't get interrupted by ON INTERRUPT but they would get interrupted by DT's fast interrupts.
I would think you could easily go into the I2C macro's and add a couple of lines to turn the interrupts on and off before and after the I2C command (or do it manually each time an I2C command is executed).
Forget that other link. I think this one is better:
http://www.i2c-bus.org/I2C-Primer.520.0.html
