firmware code for pic18f252
Results 1 to 8 of 8
    Mar 2008
    Default firmware code for pic18f252
    since no one would review my c-code on this subject, ih have decided to modified suogata bacis code on sine wave inverter thread. i am using PIC16F72 for the evaluation because that is the processor that is readily available with me now.
    The picbasic iam using is the demo version and so i appriciate that i can't run a code more than 31 command line.however upon trying to compile the code ,the following erros are reported:
    1: Error line 116 :redefinition of label T0CON
    2: Error line 119: bad expression
    3: Demo limit of 31 command line exceeded (this is understood)
    pls, can any one fix these problem for me?.
    (a): With the way the modified code stands,can it generate two complimentary sine pwm signals DRIVE1& DRIVE2?.if yes how do i include a delay routine of about 470ns for dead-time control between the two signals?
    (b): If the code cannot generate the two complimentary sinepwm signals what do i do to fix the stuff?.
    regards,
    babalola.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
