Pic16f84a Question ?
Results 1 to 4 of 4
    Bombay, India
    Here's a little pseudo code for you
    OldValue var byte
    repeat
    if oldvalue <> PortB then
    oldvalue = PortB
    SendInteger PortB
    forever
    Sendinteger is a function to send the numeric value of PortB as a string.
    With the above code, you will send only when there is a change from the previous value.
    Good Luck
    Jun 2007
    and what about pic basic ?
    i neverd used pseudo befor .
    thanks
    Bombay, India
    Pseudo code shows the logic. You have to implement it in PicBasic or any language you choose.
  1. pic18f4550 & pic16f84a serially ?
    By amenoera in forum Serial
    Last Post: - 1st March 2008, 10:51
  2. Serial Communication Using PIC16F84A
    By fazan83 in forum GSM
    Last Post: - 22nd January 2007, 02:56
  3. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
  5. PIC16F84A - Quick question
    By samuelbarber in forum mel PIC BASIC
    Last Post: - 29th June 2005, 14:32
