Bit stuffing problem!
Results 1 to 14 of 14
    atomski's Avatar
    atomski Guest
    Sorry, abt that my bad Here are the defines:
    DEFINE OSC 20
    Rx_Data Var Byte[7]
    Rx_Byte Var Byte
    Rx_Bit Var Bit
    Pulse Var Word
    I Var Byte
    w Var Byte
    ... and it's not .byte7 and .byte0 it's byte.bit7 and byte.bit0
    BTW I found a typo in my snippet:
    Rx_Byte = Rx_Byte << 1
    Rx_Byte.0 = Rx_bit
    the actual code is:
    Rx_Byte.0 = Rx_bit
    I'm trying to receive 7 bytes of data, each containing 6 bits
    (bit.7 and bit6 are not used). Data received per w loop looks
    like this: 01001000 = $48 but I've sent 00100100 = $24. So,
    you see all bits are shifted one place to the left towards MSB.
    What am I doing wrong here?
    YZ7REA Vladimir
    Last Post: - 14th June 2016, 07:55
  2. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  3. Microcontroller with 2 way paging application problem
  4. DMX512 Problem ..Schema+Code
    By programmer07 in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 15:39
    Last Post: - 6th March 2005, 01:07
