FREQOUT compiler error on USB Pic
Results 1 to 26 of 26
    Quote Originally Posted by mindthomas View Post
    Ohh, so you have a number you save in a WORD, and then split you the WORD up in two BYTES and then you send the BYTES, but can i then get them to one number again in visual basic? And can you also do it the other way, so i have a number higher than 255 would like to have send to the PIC?
    I Hope you can help me, and it would be great if you could make som code examples
    Read the book...again...search the forums. There's plenty of info out there, more than enough.
    Mar 2008
    I have found out... Your code was perfect, i could also just have looked in the book
    Then i used your code in the PIC and this code in Visual Basic
    Function LOBYTE(ByVal w As Integer) As Byte
        LOBYTE = w And &HFF
    End Function
    Function HIBYTE(ByVal w As Integer) As Byte
        HIBYTE = (w And &HFF00&) \ 256
    End Function
    Just so others can see it, if they maybe need it!
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 19:44
  3. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 13:00
  4. Replies: 15
    Last Post: - 30th October 2007, 20:25
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
