Led + resistor ?
Results 1 to 8 of 8
    You need to check the data sheet for the specific PIC device you are using. Not all pins are direct drive. Some are only open collector and need pull-ups if you need a high output. Also, what level are you using to turn your LEDs on? The I/O pins will drive a higher current for a low(8.5 mA) than a high(-3 mA). So the best bet is to connect the LEDs to you positive rail to the anode and the I/O pin to the cathode.
    Thanks falingtrea, that is a good idea.
    In fact i was going to change my code to do that by i remembered that one of the ports i mentioned is one bi-color led ( green and red with comon anode ) and the green one doesn't light up.
    This was what i changed :
    PortA.7 and portB.4 added a 2K resistor in series.
    Remaining ( working ) ports...left as is ( meaning...without resistors )
    Result :
    Now all led light up normally !!!
    Still, i have to mention the hardware feature in these 2 ports that produce this behavior.
    I searched the 16F88's datasheet and i could not find anything that could link to this .
  1. Can I drive a 5v LED without a current resistor?
    By Fredrick in forum Schematics
    Last Post: - 11th September 2009, 15:42
  2. Calulating BJT base resistance for PIC led switching?
    Last Post: - 20th November 2008, 09:41
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  4. LCD will not start
  5. can't even flash an LED
    By bruno333 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2005, 14:27
