Hi Skimask,
Changed ADCON1 to $f, but no joy (if that's what you meant).
Phil.
Hi Skimask,
Phil.
Skimask,
Also changed ADCON0 to 0 (just in case),
Serout2 works OK (same pin) but that's not the point!
Sanity rapidly departing, need to go away and have a think.
Thanks for your help - another brain always sees something different!
Cheers,
Phil.
If SEROUT2 works, and DEBUG doesn't work, it's gotta be the way you config'd DEBUG
Check your upper/lower case...ALL CAPS on the DEFINE's
Check your modes...
Post your codes...
(hey that rhymes!!!)
NOTE: Changing ADCON0 isn't going to do anything to the pin. It's only going to shut off the A/D module.
I think I see your problem back in the 1st post:
If this is the code you're using...what's wrong with this picture?Code:DEFINE OSC 8 ' Tell PicBASIC define DEBUG_REG PORTA define DEBUG_Bit 1 DEFINE DEBUG_BAUD 9600 DEFINE DEBUG_MODE 1
The problem is very subtle. I missed it a dozen times. Check page 31 of the manual.
Yeah, saw that too, changed define to DEFINE both times (double checked with Notepad).
No joy.
I'm just going to stick with Serout2 for now - it's less painful! I'll sort out DEBUG later.
Thanks for all your posts!
Phil.
Change DEFINE DEBUG_Bit 1 to DEFINE DEBUG_BIT 1 and it should work.
Having the last 2 characters in lower case was making pin RA0 an output VS RA1.
At least is was in MPSIM. I don't have a 737 to test, but this works fine in MPSIM once
I change Bit to BIT.
There's a section in the library that sets up default values, and if something isn'tCode:@ __config _CONFIG1, _INTRC_IO & _MCLR_OFF & _DEBUG_OFF & _WDT_OFF & _CP_OFF ' Defines DEFINE OSC 8 DEFINE DEBUG_REG PORTA DEFINE DEBUG_BIT 1 ' note it's all UPPER CASE DEFINE DEBUG_BAUD 9600 DEFINE DEBUG_MODE 1 ' 1 = inverted ' System Constants OSCCON = $F0 ' set 8MHz internal ADCON1 = $0F ' all digital CMCON = 7 ' comparators disabled ' Code start Init: PAUSE 100 ' let things settle DEBUG "Start",10,13 GOTO Init END
DEFINED, the value will be whatever the default is. In this case it's 0.
ifndef DEBUG_BIT ; Debug pin bit
DEBUG_BIT EQU 0
If wasn't seeing DEBUG_Bit as DEBUG_BIT so the default was RA0.
