Try this for your config statement:
@__CONFIG _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF & _BODEN_OFF
Thanks for trying Joe, but that didn't do it. I think there's something fundamentally wrong, as the compiler doesn't know about 16f689.
I don.t know what version you are using, look into your PBP directory and see if you have a file16F689.inc, also see if the code compiles with a similar chip. OK here is the data sheet:http://ww1.microchip.com/downloads/e...Doc/41262B.pdf
Yes, the file is there. And I already have 2 copies of the data sheet, thank you!
Here are the first three error messages:
Error [132]c:\pbp\16f689.inc 20: Unknown processor (16f689)
Message [301] c:\progra~1\mecani~\mcs\p16f689.inc 32: MESSAGE: (Processor header file mismatch. Verify selected processor.)
Error [131]c:\pbp\16f689.inc 22: Processor type is undefined.
Many more errors.
If you have installed the latest version of MPLAB,
the MPASM files should be located in the C:\program files\microchip\mpasm suite folder.
Sometimes the Find Automatically button doesn't find the correct folder.
In MCS, go to the View | Compile and Program Options | Assembler Tab
Click the Find Manually ... button and point it to
Then check the Use MPASM checkbox.
