DT Instant Interrupt counting
Results 1 to 13 of 13
    Quote Originally Posted by jderson View Post
    ERROR: Variable wsave3 position request 416 beyond RAM_END 367.
    Can someone help, please? Thank you!
    I will try, not every chip has that address available. Open Darrels code and insert a semicolon just before the call to WSAVE3, he gives you instructions in the comments above that.
    Thanks Joe. I commented out the offending line, and also the "T" line in the "Reenter" program. It now tries to assemble, but comes back saying "unknown processor 16f689". I removed the line at the top of my program about the WDT, but it still does the same thing. How does it know I'm using a 16f689?
    Because you selected that processor in Microcode Studio, up at the top. When it compiles it includes the appropriate files for that processor. Oh and this too @ DEVICE pic16f689,wdt_off,
    Note: you must use the MPASM assembler with Darrel's includes.
    I removed the @DEVICE line, and I have MPASM enabled. It is MPASM that is generating the errors. I think the problem has to do with where all of the various components are located, relative to one another. (MPASM can't find the P16F689.INC file) I'm still reading.
    Try this for your config statement:
    @__CONFIG _HS_OSC & _WDT_OFF & _PWRTE_ON & _LVP_OFF & _BODEN_OFF
    Thanks for trying Joe, but that didn't do it. I think there's something fundamentally wrong, as the compiler doesn't know about 16f689.
    I don.t know what version you are using, look into your PBP directory and see if you have a file16F689.inc, also see if the code compiles with a similar chip. OK here is the data sheet:http://ww1.microchip.com/downloads/e...Doc/41262B.pdf
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Ping Darrel Taylor - Timer0 Instant Interrupt
    By JEC in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 11:20
  4. Replies: 1
    Last Post: - 2nd November 2006, 23:24
    Last Post: - 6th March 2005, 01:07
