Analog port newbie questions
Results 1 to 10 of 10
    Feb 2008
    You set AN3 as Vref+. What do you have on AN3?
    Try setting Vref+ to internal +5v and see what happens...
    For the first code, I have a voltage regulator giving 2.5V to AN3.
    I have tried using internal 5V Vref+ for the code below
    define osc 20
    define adc_bits 10 'define number of bits in result
    define adc_clock 3 'clock source3=RC
    define adc_sampleus 50 'set sampling time in microsec
    trisa = %11111111
    trisd=0
    adcon1 = %10000010
    adc var word
    start:
    adcin 0, adc
    if adc > 10 then
    high portd.0
    low portd.0
    goto start
    and i input the same 2.5V into channel 0, but I cannot get portd.0 to go high ? Ive also tried changing to 'define adc_clock 2' or (20Mhz which is same as my OSC freq).
    Which version of PBP are you using?
    And try
    adcon0 = $c1 : adcon1 = $f0
    Feb 2008
    And try
    Im using PBP 2.47. I tried to change adcon1 and add adcon0 but it still doesnt work. Is the problem in my code or is my port A burnt (I accidentally input ~10V for a short while into the Vref+ pin earlier) ?
    Is anything wrong with the quoted code ?
    Any help is appreciated.
    Feb 2008
    OK, I found the problem, turns out the defines must be in block letters. Weird that I did not get any compile errors though.
    Quote Originally Posted by rngd View Post
    Which is exactly what the PBP manual says will happen...
    Feb 2008
    Yeah, too bad for me, I did not not read the part about the defines
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 11:34
  3. Microcontroller with 2 way paging application problem
  4. Hi Everyone! Some newbie questions :-)
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2006, 23:24
  5. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
