Analog port newbie questions
Results 1 to 10 of 10
    Feb 2008
    Default Analog port newbie questions
    Hi guys,
    Im having trouble using the analog port. Regarding the analog port A, is it supposed to output high (approx 4.8V) when its not connected to anything ? I have set trisa=%111111.
    Ive programmed everything else correctly (I think), after reading some good guides on programming for port A.
    The problem is I have a photodiode which has open circuit voltage of 0.25V but when I connect it to channel 0 it jumps to 0.40V for some reason. The Vref+ is set to 2.5V.
    Thanks all.
    edit: I suspect that something is wrong with my port A. How do i check ? Anyone have a working test code ? Im also testing it now ..
    Mar 2006
    China
    Default Port A is a bit different
    What PIC do you use? Port A usually contains a lot of stuff such as comparators and A/D and there fore requires some more registers to be set before it is working properly.
    What do you have connected to your port A and what do you want it to do? Do you want all pins digital? or just some and the others A/D.
    To help you we need some more info such as mentioned befoer PIC, simple circuit description, a clear idea of your expected end result and some beer.
    The beer most of us already have so you just add the rest and we will see where the problem is.
    /me
    Feb 2008
    Hi jumper, these are my settings for ADC
    define OSC 20
    define adc_bits 10 'define number of bits in result
    define adc_clock 3 'clock source3=RC
    define adc_sampleus 50 'set sampling time in microsec
    adc1 var word 'store adc input values, adc1=AN0/RA0
    adc2 var word 'AN1/RA1
    adc3 var word 'AN2/RA2
    adc4 var word 'AN4/RA5
    trisa = %11111111 'port A all input
    adcon1 = %10000011 '1 for Result Format Selection Bit because using 10 bits
    '0011 for AN4, AN2, AN1, AN0 analog port. AN3 is
    'Vref+ reference voltage
    pause 500 'wait .5 second
    Im using the 16F877A. This is my main program and it is supposed to input 4 analog values, do some comparison and then high some ports.
    Ive tried a simpler version to test out the port also,
    define osc 20
    trisa = %11111111
    trisd=0
    adcon1 = %10000010
    adc var word
    start:
    adcin 0, adc
    if adc > 10 then
    high portd.0
    low portd.0
    goto start
    When I input 2.5V into porta.0 the LED does not turn on. If I leave the pin floating (5V) then it turns on. If I change the code to 'adc>0', it turns on.
    edit: I think the port A of my PIC is fried. When power is on but nothing is connected, the port A pins are at 5V. Is this normal ? Help pls !
    You set AN3 as Vref+. What do you have on AN3?
    Try setting Vref+ to internal +5v and see what happens...
    Feb 2008
    For the first code, I have a voltage regulator giving 2.5V to AN3.
    I have tried using internal 5V Vref+ for the code below
    define osc 20
    trisa = %11111111
    trisd=0
    adcon1 = %10000010
    adc var word
    start:
    adcin 0, adc
    if adc > 10 then
    high portd.0
    low portd.0
    goto start
    and i input the same 2.5V into channel 0, but I cannot get portd.0 to go high ? Ive also tried changing to 'define adc_clock 2' or (20Mhz which is same as my OSC freq).
    Which version of PBP are you using?
    And try
    adcon0 = $c1 : adcon1 = $f0
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 09:38
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
  3. Microcontroller with 2 way paging application problem
  4. Hi Everyone! Some newbie questions :-)
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2006, 22:24
  5. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
