How do I know if a PIC is dead ?
Results 1 to 9 of 9
    Hi rngd, If you have a suspected dead PIC try erasing it several times, this sometimes works.
    Feb 2008
    OK, so I guess its probably not dead then. Thanks.
    Oct 2003
    Australia
    Wink
    Rngd,
    For times like these (suspect RIP pic) I load it with a very simple LED blinky program which flashes all the ports on and off. If that works than I know that the pic is OK.
    ;P
    Squib
    Quote Originally Posted by Squibcakes View Post
    Rngd,
    ;P
    Squib
    Amazing how it always goes back to ol' blinky isn't it?
    Mar 2008
    Ya.. It's a good basic beginner, and testing code
    If you did something to the Vref pin, you only may have messed up the analog circuitry. I would do an LED check of the specific pin you overvoltaged. Also was the voltage directly on the pin or through a series resistor? The resistor would have probably protected the pin.
    Tim Barr
    Post
    Overvoltage with no current limiter is more or less a bulletproof way to fry a pin on a pic. I've never seen the entire pic beeing fried from it though.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 21:01
  4. Two PIC 16F877A fried in two days!
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 10:38
